Air Cleaner Lid Too Tall?
Car: 92 25th Anniversary RS
Engine: 305ci 5.0L V8
i have an annoying problem. i put on a 14x3 open element air cleaner, i removed the spacer ring, and it's still too tall for the stud to go through the lid! right now i have it tightened with the air cleaner lid upside down, but i want it done the right way. is there a way to extend the stud? will a flat lid such as the k&n extreme work? im so aggravated
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Air Cleaner Lid Too Tall?
Go to Home Depot, Buy a longer stud, bend to match and cut to length. Take the old stud with you so you can match the threads.
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
well just twist the rod and loosen it just like it was straight. there is some room for it to be higher. Be careful of the injector wires though.
That's what i did, but then again the lid then hit the hood which caused me to flip it upside down again.
Be very careful of the clearance. I know my setup is different but room is at a premium. (have a L69 w/ a non drop base attached at the bottom and a much bigger than stock air cleaner that sticks out by two inches beyond the top of the air base. I'm doing the extreme lid next for lots of flow)
i dont have the machinery to bend it or else i would. im sure everyone with a 14x3 air cleaner has had this problem and im trying to find out an easy fix to make it look right
If you get a drop base aircleaner, you would not have this issue, although you would have to keep the restrictive "ring" inbetween the aircleaner and TBI.
OH yeah, a hacksaw to cut it to length after you bend it.
Transmission: 4L60
and with the top that flows it will be more than enough. I still say take the spacer out (if you have a non-drop base and unscrew the stud a little and it will fit fine if it is only 2.5" tall.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
To fit 3" with good hood clearence the flat base needs to be adapted to its lowest (3mm over the trottle linkage). Or flat flat and grind the trottle lever like some heawy-metal tgo member.
Looking forward to see your set up
i found offset studs online. will one of these work? and does anyone know the stock thread size?
Car: 91 Z28
Engine: 5.7 TPI
Transmission: 700R4 Probuilt Hardparts
Axle/Gears: G92 3.23
any ones of what work??? no links up there.
the "Z-Stud" is 1/4" coarse thread.
IT's up to you, but have you removed the hood insulation?? I'd leave it if its still neat and intact. If its tore and fugged up, then take it off. That'll help a little... but beware of water dripping back in on the distributor===most everyone says that it stays dry after doing it anyway. I havent removed mine cause its still neat.
I put on an air inlet system, ""ram air box" and had to modify the fiberglass. it's got a 6" inlet on it, 14x3. it's a little excessive, but is way functional. I'm kinda pissed that it wasnt ready to slap on--and i had to get stoned from the fiberglass compounds. Damn those lazy aftermarket middlemen and their generic promises.
www.ramairbox.com
www.ramairbox.com
I think the thread is considered 1/4x25
Car: 91 Camaro RS
Engine: 383 FiTech
Transmission: T-56 BW
Axle/Gears: 3:42 10 Bolt
If you go to an Auto Zone they have an extender that wount with the stock one. its like $12 cuz i had the same problem and did that and it works fine.
mission accomplished! i used the spectre adjustable stud kit (got it at autozone) and managed to get it on the right way. ill post pics wen i can...
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
