which heads out of these two
Old Apr 26, 2008 | 08:30 PM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
whats a better set for me the 416's with 1.94/1.5 valves or the chevy bow tie casting #14011034 with 2.02/1.6
any help would be great
Old Apr 26, 2008 | 09:55 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
Re: which heads out of these two
I'm currently running a set of the bow ties on my setup and I love em'. I'm using them with 10.8:1 cr and I ran them right out of the box initially. Last year I pulled them and had some additional porting and blending done and noticed a little more mid range. If your CR supports the lager valve, I'm a big supporter of more is better in this department.
Old Apr 27, 2008 | 04:00 PM
Colts45s's Avatar
Car: 92 camaro rs
if i have the cr to support them? im running 416's 305 tpi heads. I would have assumed going to these heads i would actually lower my cr.
Old Apr 28, 2008 | 12:44 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Out of those two options, without a doubt go with the bowtie heads. Even if you have to machine it down to up your compression ratio, it would be worth it. The bowties are actualy pretty darn good heads, as GM Iron heads go.
Old Apr 28, 2008 | 12:41 PM
Colts45s's Avatar
Car: 92 camaro rs
now i just have to figure out wich intake manifold to buy or if i can use the performer i got. cause on jegs.com it actually says it will not fit bow tie heads
Old Apr 30, 2008 | 09:05 PM
Yes, you are correct...going to a larger displacement head would lower your compression ratio. There's a balance between increasing air flow and having the proper cr to support the increase in flow. As the other member stated I would go with the ci bow ties. If you have them milled some prior to installing them you would see a low end increase due to the milling increasing your cr. Thats what I would do anyways.
Brandon
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
