TBI injection on 355 vortec with LT1 cam, issues?
Old May 10, 2008 | 03:01 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I need to know what to expect, i usually do carbed but it is my wifes 86 TA and i want it injected for he dependability.
First off, it is a TBI 350 from a 90 chevy truck with original TBI harness and TB, it runs great but smokes like all hell apon fire up from the old valve guides.
Now, i have a set of ported and polished vortec heads i had on a 383, the might be excessive but i am not re using the swirl port heads.
It is a vette LT1 cam, vortec heads, .030 over block, 9.7 to 1 forged pistons. I bought short block for 300$, i know it doesnt need the forged slugs.
I hear that you dont even need a tuned chip for a LT1 cam swap sometimes, sometime i hear you do, i found nothin really useful in a search so i am asking for the TBI gods help for answers. I hope for 300 HP but if it falls short no biggie, i am sure it will make 350 ftlbs. It has headman shortys and Y pipe for the exhaust too.
What you think fellas, will i have hell with a unburned chip? I will be using a performer intake with the adapter plate for the TBI.
Old May 10, 2008 | 09:21 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: TBI injection on 355 vortec with LT1 cam, issues?
Another Questin, is the EGR a must, do i have to have it for the TBI to work properly?
Old May 10, 2008 | 11:05 AM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Transmission: 700r/manual
Your not going to be able to drive that with a stock tune, it will be an undrivable mess. You can make it work wiithout egr, but you will sacrifice 2 or 3 mpg.
Old May 10, 2008 | 01:51 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Who is the cheapest for burning a chip? I heard in the past there are burners who just need to know what the specs of the motor are and they get it right on the first burn, then of course you have to re burn every time you do a major mod but i will be leaving it alone.
Old May 10, 2008 | 02:18 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
You're going to have to learn to tune your own chips. Was the car originally EFI or carbed? Your going to need to install at least a TPI fuel pump. Also bump up the fuel pressure. For injectors you could probably use 65#/hr or 90#/hr big block injectors.
Old May 10, 2008 | 02:47 PM
DM91RS's Avatar
Car: 91 RS
To make a long story short I installed the exact same thing but with 1.6 roller rockers in 2001 or so. Had a prob with the block and installed all the parts on a 305. Mucho tuning so far.... so you be the judge. It ran but not well at all and that's what started me with DIY tuning and I am still trying to learn. But the old 305 I have does haul axx and get's around 20mpg with mixed driving. If you catch on well you can do better...........
Old May 10, 2008 | 06:22 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
damn, you guys got me thinking screw it and thow a 650 holley on the thing and call it good... I dont have a lap top and didnt want to spend any money on a tuning kit.
Old May 10, 2008 | 08:58 PM
DM91RS's Avatar
Car: 91 RS
I myself was not trying to discourage you but just a dose of reality. Don' t get me wrong when I say "still learning". That's a good thing. If I had went carb yes it would have been easier but it would also not taught myself [with help] about what fuel or lack of does and the same goes for timing.
In my case, with my wife's 84Z fuel injection would be great but, with what it came stock with has never gave a minute of trouble. I'm not gonna push my luck and have issues with her car even after changing engines in it. [soon]
Old May 10, 2008 | 11:17 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, i think a fuel regulator with return style setup and a holley 650 woll do just fine, i dont havr the time money and patience for the injection then.
Old May 12, 2008 | 10:43 AM
Ronny's Avatar
emissions testing in Houston?
Old May 12, 2008 | 12:21 PM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
My sentiments exactly. There are people out there that claim they can burn a custom chip for you just by a list of mods, but they are Ive tried hypertech, and tbichips, im on my 7TH chip, so in short NO they can not burn you a good chip that way. My car runs, but not good at all. Carb is much cheaper and easier to work with.
Old May 12, 2008 | 02:43 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I am EXCELENT with a carb, so i am just finding a 650 holley on Ebay and a return regulator. The regulator returning so much fuel will not burn the pump up i am sure right? Arent they only good for 15 PSI?
Yea, we have it, what about it?
Old May 12, 2008 | 02:55 PM
Ronny's Avatar
Will car pass inspections with a carb? visual or sniffer? or both. Wisconsin Metro Milwaukee only does sniffer per my experience with OBD1 systems in past.
Old May 12, 2008 | 10:54 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I will make it pass.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
