chugging
Old May 12, 2008 | 05:20 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
chugging
Ok so...
Awhile ago was having problems with the car before the fuel pump issue...
Well was able to take the car out for a drive today and the issue is still there... When you accelerate sometimes it will make like a chug noise when you first press the gas or a few times it will make this noise then will start to pick up speed and what not... Any idea on my problem?
Old May 12, 2008 | 07:36 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: chugging
so are you in overdrive when this happens? are you sure it is not pinging?
Old May 12, 2008 | 07:38 PM
naterman35's Avatar
Engine: 305--
Axle/Gears: 2.73--
Re: chugging
yeah in overdrive.... its sort of a "duhhhhh wroooom"... like sounds like it just died then accelerates.. but it doesn't accelerate quickly or anything.
Old May 12, 2008 | 07:58 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: chugging
are you going uphill? liek up on on ramp or something? whats the timing set at? if thats the case try taking it out of overdrive and see hot it feels, my old 305 used to ping going uphill or on ramp in overdrive because the torque multiplication was decreased in overdrive causing the engine to overwork and ping.
Old May 12, 2008 | 08:24 PM
naterman35's Avatar
Engine: 305--
Axle/Gears: 2.73--
Re: chugging
nope happens on flat road.. i tried out of over drive and still does it. It sounds like it completely died... not pinging.
bonz
Nov 2, 2003 11:43 AM
grafx
Aug 23, 2003 12:31 AM
firebirdkid
Jul 13, 2003 10:29 PM
IROCThe5.7L
Aug 7, 2002 01:03 PM
Dan87IROC-Z
Mar 12, 2001 12:25 PM
