305-350 ESC Question
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
I searched and didnt really find a direct answer, im collecting the last few pieces of my 350 swap (ESC, Chip, Injectors and fuel pump) and i need to know if i can use a 350 TPI ESC on my TBI?
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: 305-350 ESC Question
Knock Sensor The knock sensors are different between 305s and 350s, and also different between MAF systems, and Speed Density (primarily becuase the MAF has an external ESC module, and the SD is internal to the ECM.) So purchase accordingly.
thanks google :wink: took me about 20secs to find this
Car: check
Engine: check
Transmission: check
RBob.
Say i pulled one from a 350 TPI GTA, that would work correctly on my TBI?
And what is a CCC camaro or firebird? Ive never heard of that?
Thanks, im just trying to understand this down to the dot, im not very familiar with this kinda stuff just yet.
Car: check
Engine: check
Transmission: check
The TPI MAF f-body knock sensors and ESC modules are 100% compatible with the f-body TBI systems. The knock sensor (KS) will measure about 100K ohms resistance, where the SD knock sensors are about 3.9K ohm resistance. The SD KS will work, however, they tend to produce a constant low level of reported knock.
As long as it is a MAF car it will work. I'm not sure if you are speaking of the knock sensor (KS) or the ESC module. If it is the KS measure the resistance to double check the application. The ESC module is plug & play. Same connector, same functionality.
Computer controlled carb, the electric q-jet setups. The ESC module uses a 4-pole filter instead of a 2-pole on the newer models.
RBob.
RBob.
Car: '92 Z28 25th anniversary/ '89 RS
Engine: 400 sbc
Axle/Gears: moser 12 bolt w/4.10
i was told that the esc and knoxk sensor is different from a 305 and a 350. as for using one from a tpi, i have no idea. when i did mine i used one from a 90 caprice with a 350 tbi
Car: 91 RS
I hope you make sense of that...lol
Thanks.........DM
Car: check
Engine: check
Transmission: check
RBob.
Hmmmm........ so you're saying that I could pull one from my 1984 Z28 parts car and it "would/might" get rid of the "false" knock we talked about in the other thread where you said the newer modules were more prone to filter less?
Thanks.........DM
Thanks.........DM
RBob.
Thanks you really cleared that up for me, Ive been looking for one for quite awhile and didnt know if i could get one from the classifieds on here, quite a bit more 350 TPI cars get parted out on here than someone who has done a 350TBI swap, and sadly the JY's around here are well picked over and they always rip out the engine, and as far as i know on most trucks and cars its located near the Throttle Body as opposed to the drivers firewall like our cars because i havent had any luck finding one myself.
Car: 91 RS
[GUOTE]
A good possibility. As long as the parts car ESC module is factory original. Do I recall correctly that the reported knock may be from driveline slack being taken up?
RBob.[QUOTE]
Yes sir you are correct. I'll check to see what modules are on the cars.
Thanks........DM
RBob.[QUOTE]
Thanks........DM
Engine: LS1 / L03
So how exactely would you be able to use a early 3gen ccc module on a tbi when the pins are different?
from what i understood from this thread, the 100k are the better esc sensors, but the ccc modules are filtering the knocks better.
Car: check
Engine: check
Transmission: check
The 100K sensor is not necessarily better then the later 3.9K sensor. It is that the output impedence is a better match for the external ESC modules. It is also the proper sensor for those vehicles using an external ESC module.
The 3.9K sensors are that value to match the ECMs malfunction diagnostic routine. Those ECMs actually read the resistance of the sensor to prove out the wiring.
Using a 3.9K sensor with the latest 350 ESC module (HKR) has the module continuously reporting knock. Low levels, but the counts keep on going.
RBob.
Engine: LS1 / L03
so is the 100k used with the external module or the 3.9k? i measured my new KS resistance at 100.5k, is this ok for the 89 tbi? i cant quite figure out which years/systems were using which kind of KS..
when there is no external module, does it mean the ecm does the esc handling?
Car: check
Engine: check
Transmission: check
The 100K sensor is to be used with external ESC modules.
In this case the ESC module is internal to the ECM. It is mounted on the MEMCAL. There is a picture of it in the sticky's on the DFI & ECM forum (here at TGO).
RBob.
RBob.
Engine: LS1 / L03
thanks. on thirdgen, one can really learn new useful stuff every day
