Throttle linkage too long on 5.7L
Old May 20, 2008 | 09:57 PM
midget_man1387's Avatar
Car: 1990 Camaro RS
Engine: 5.7L TBI
Transmission: 700R4 w/shift kit
Hey guys, I'm having some problems with my throttle linkage being about an inch too long on my recently swapped 350. I believe we are still using the linkage from the 3.1 V6, so that might be my first problem.
Should I be running a linkage from a 305 TBI since the van one would likely be way off?
Also, I'm not sure if this matters but while the throttle linkage is about an inch too long, it looks like our kickdown cable for our 700R4 is about an inch too short. Is there some sort of adjusting that can be done to fix both of these problems at once?
Thanks in advance.
Old May 23, 2008 | 07:15 PM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
Re: Throttle linkage too long on 5.7L
do a search but on my 92 700r4 the detent neded to be adjusted of course i pulled slack right at the gass peddle, but it's been 2 years now. especially read the stickie on the engine swap it tells about the different throttle linkage geometry that you have to adjust
Old May 27, 2008 | 02:37 PM
Ronny's Avatar
you can purchase an adjustable throttle cable bracket.
Street Lethal
Apr 30, 2019 12:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Thornburg
Aug 27, 2015 08:33 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
