A Bolt Fell in to My Throttle Body?????
Old May 25, 2008 | 01:03 AM
408chevymob's Avatar
Car: 1991 RS
Engine: 305 TBI L03
Ok, little explanation needed about how it happend. But while working on my car a bolt fell down in to my throttle body, I did not know this until I drove about a block and started hearing a knocking noise and my car died (like it was getting no fuel). The injectors are still spraying fuel down.
It sounds like it would sound if there was a bolt in a clothes dryer.
What do I do?
Will the bolt eventially pass in to my exhaust? cat/muffler?
Old May 25, 2008 | 01:11 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Re: A Bolt Fell in to My Throttle Body?????
It will not pass through the exhaust, and you better hope and pray that it didn't get into a cyl, if it did, it is new motor or rebuild time.
Best thing to do, is pull the intake manifold off, and see if you can find the bolt in the intake, or in one of the intake ports on your head. Check and make sure it didn't screw up a valve. If you got lucky, and no valves are messed up, and it didn't get into a cyl, then thank your lucky stars, and buy a lotto ticket. Chance are, if it was a small bolt, that the noise you heard, was the bolt in one of cyls, beating itself between your piston and the head, in which case you are looking at a rebuild, or a new motor, depending how much damage there is.
Sorry man, this is why we don't put bolts near opens that we can drop them in.
--John
Old May 25, 2008 | 04:21 AM
DM91RS's Avatar
Car: 91 RS
My experience with this was not a good one. One of the fuel injector pod bolts [one of the three] cam loose and went into the engine while running. I knew nothing about it until the engine started knocking. Long story short, cracked the cylinder wall in a 3 month old GM L31 block.........
Old May 25, 2008 | 12:43 PM
CaddyMan's Avatar
Car: 1990 Cadillac Fleetwood Brougham
Engine: Chevy 350 TBI with some goodies
Transmission: TH-7OO-R4, waiting for rebuild
Axle/Gears: Stock. Saving for 3.73 posi unit.
Keep us posted on the news. I am just curious as to what happened. (As far as damage) Hopefully you can pull the manifold off and the bolt will be sitting right there. Good luck.
Old May 25, 2008 | 01:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
*subscribed*
Old May 26, 2008 | 03:48 PM
Car: 1991 RS
Engine: 305 TBI L03
I am not 100% sure that is what happen but that is what I am assuming. The person who owned the car before me put on k&n airfilter/intake. It was manufactured to have three screws in it that come out of the top of the throttle body and they plugged the third hole with a small bolt that I think fell in while doing a tune up.
I will give more details about the damage done when I get more.
Old May 26, 2008 | 08:20 PM
Ruiner's Avatar
Car: '91 Camaro RS
Engine: 355 TPI, Comp 268xfi, bowtie heads
yeah I dropped one of the injector pod bolts into the throttle body once but the butterfly valve caught it and I was able to pull it out, would have been a major pain if it fell into the manifold
sorry to hear that happened, hopefully it's still in the intake, but if you said you heard a knocking sound then I'm expecting the worst, cylinder/piston/head/valves are trash
Old May 28, 2008 | 03:11 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
That sucks man JR305 had the same fate of one of the injector pod bolts falling into the throttle bore, I think he may have posted pictures, but the engine didn't live
Old May 28, 2008 | 03:18 PM
DM91RS's Avatar
Car: 91 RS
I gotta tell ya that after mine happened I can see the need for safety wire bolts.
I was driving a car..........think of it happening in an airplane........bummer
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
