ECM
Old Jun 17, 2008 | 07:51 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
ECM
Hey guys. Thanks to your help I'm slowly figuring out whats up with this 350 (L05) that was supposed to be an L03 when I bought the. Its been confusing but there are definitely worse things in life than thinking you bought a 305 and getting a 350. Only problem is the swap was done half-a** and I'm having to verify everything.
So it still has the 305 ECM. I know its not running at optimum like that. The question is, I'm gonna learn to tune eventually and maybe order a custom chip to cover me until then.
Will tuning chip tuning solve the issue or is it important that I actually get a 350 computer and then proceed with tuning?
Old Jun 17, 2008 | 09:06 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ECM
The computer (ECM) is the same for a 305 or a 350. It is the calibration that differs. This is held in the EPROM, which is a removable chip.
You can get a 350 calibration (PROM) from a Caprice. However, they are a heavier car and the tune will be adjusted for that.
RBob.
Old Jun 18, 2008 | 12:21 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: ECM
RBob, why is it EPROM then only PROM as you said?
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
