iac keeps reset itself
Old Jun 28, 2008 | 06:30 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i keep set it to 1 1/8. runs fine for 2-3 mins starts popping out exhaust ,take out iac and its 1/2 inch shy of 1 1/8! why does it keep doing it?
Old Jun 28, 2008 | 08:30 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: iac keeps reset itself
the IAC, or Idle Air Control is what the ECM uses to control idle speed. it does that by either extending or retracting the plunger.
the correct way to set the base idle is,
https://www.thirdgen.org/tpimod2
Old Jun 28, 2008 | 09:22 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
if its still screwy, i say your iac is getting stuck on the return side. possibly bad internal connection.
replace it (y)
Ed1LE
Sep 30, 2018 09:14 AM
okfoz
Oct 13, 2015 02:19 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
