I have Swapped my 305 for a 350 and it runs great except when i get on it the check engine light comes on so i checked the codes it was four quick flashes and then three quick flashes. i beleive that is code 43 which is esc so i looked at it then i saw i have a 5 pin esc which i got from i beleive a 96 truck and my 92 connectors that went into my old esc. I have searched around and cant find anything on this missing wire can someone point me in the right direction?
Not exactly sure of what you are saying. However, the stock ESC module has 5 pins. The stock connector has 5 slots for pins, of which only 4 are used. The 4 wires are: +ignition, ground, knock sensor, and knock signal to the ECM.
If the SES turns on with heavy throttle it is most likely the forced knock test failing.
If the SES turns on at some random point then it is from run-away knock counts. This can be caused by a bad sensor, module, or wire.
RBob.
RBob.
So it turns on under heavy accelleration sometimes what does that mean?
Quote:
The ECM advances the SA to force knock. If no knock occurs then ECM believes that the knock detection system is not operational. This sets code 43 and reduces the timing. At key-off, key-on this test is reset and tried again.Originally Posted by keeslinger31
So it turns on under heavy accelleration sometimes what does that mean? A search on this board (TBI) for knock using my name as the poster will bring up several threads that go into further detail.
RBob.
