TBI to TPI
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
TBI to TPI
I have a TBI and it seems like your making more power with a tpi setup. So i want to know how much work it would cost to swap mine over?
thanks
kevin
thanks
kevin
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TBI to TPI
You're in the wrong forum. These guys will tell you keep the TBI.
Look at the TBI to TPI tech article on this website, then do a board search for all the threads from people who have done the swap before you. Check out the Engine Swap forum, and the TPI forum specifically.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: TBI to TPI
TPI swap needs to include TPI heads, TPI fuel pump, TPI exhaust, TPI computer +tune and ev. cam depending on wich stock performance configuration you like.
To make the same hp with your stock TBI you need, TPI fuel pump, AFPR with a stiffer spring, TPI exhaust, tune (easyest with EBL) and cam depending on wich TPI hp configuration you like for reference.
This is what I came up with wenn I was searching.
Re: TBI to TPI
You dont have to swap the heads. My dad's old car made 176 RWHP and 290 RWTQ with the stock TBI peanut camshaft and heads and a TPI intake. Putting in an LT1 camshaft netted another 11 horsepower but no change in torque. The TBI engine made 158 RWHP and 220 RWTQ.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: TBI to TPI
TPI/TBI 305 hybrid
Car: Camaro RS
Engine: obd2 350 lt1
Re: TBI to TPI
wow that picture is confusing. anyway the only reason tpi guys are making more power than tbi is that noone is using tbi so just get better heads, cam, intake, exhaust, tune and you will be rolling with the tpi guys in no time. just my
Re: TBI to TPI
The tune is the hardest part of the TBI system. I'm told the EBL replacement computer is a real step up in that area.
evilstuie
Jan 9, 2020 08:29 PM
Sanjay
Aug 12, 2015 03:41 PM
