Guys help me with the bin for my non stock L05
Old Jul 23, 2008 | 04:29 PM
Dmity Kiev's Avatar
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
Where i can get ready to use bin file for my Pontiac firebird 91 L05 TBI with Holley 670cfm truck , 1,2 bar fuel pressure, Vortec Heads , Vortec intake , Comp CAms Advertised Duration 258/ 264 , 180 Degree thermostat, Headman Hedders , 3.0 Flowmaster Full system , 3.23 Posi Diff + TH700R4 . houp to take about 300-320 HP . help please becouse here in Ukraine i dont have a guys who can modify my stock bin (ECM and engine i bought from police caprice) thanks . at this time i make some changes in my bin file here it is , can you guys tell me is it good specs i make http://rapidshare.de/files/40066478/Fire.bin.html
Old Jul 24, 2008 | 09:21 AM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
Re: Guys help me with the bin for my non stock L05
Hi, Dmity. I have not yet done any tuning myself, so I'm no expert, but I have been reading a lot on here about it. Check out this post. https://www.thirdgen.org/forums/tbi/...free-tune.html
You have to read down a ways but there are quite a few bin files posted in the thread (there are five pages of posts, so you will have to look). You can proabably find one to get you close. I think there is also a library of bins on the moates website here: http://www.moates.net/info_pages.php?pages_id=14 You will have to use the guest username and password given on the website to access the files.
Finally, I plan to use RBob's EBL Flash progammer when I start tuning in the near future. It will let you plug a laptop directly into your ECM and get real time performance data. It also lets you store 8 bins at a time so you can go out and compare different tuning settings or have alternate bins, such as one for power and one for high gas mileage. The EBL comes with something like 30 pre-made bins, so you can probably find one that works good for you. The website is www.dynamicefi.com
Its great to here that there are firebirds as far away from here as Ukraine. I hope this was helpful.
Old Jul 24, 2008 | 09:55 AM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
Privit Dmity,
I am definitly not an expert on ecm's i ripped mine out and went carb.. but its nice to find out that there are other ykpaiinchi that love third gen's...
Just wanted to stop in and say hi
John (IBAH)
Old Jul 24, 2008 | 11:22 AM
Ronny's Avatar
First step is remove chip from ECU- read it with appropriate hardware- and save it( I use TunerPro). That is the base tune you will need to modify.
Or you can do same with your Firebird chip if they use the same ECU. I believe they both use the 8746 ECU(unless Caprice is TPI?). Then you would need to change the BPC in addtion to other items if you are using the Firebird chip. That you be my preference?
Next is datalog and you will need a ALDL cable and datalog program(free?).
Datalog will tell you what the sensors are seeing and show you what may need changing(harder part).
As suggested read the stickies a dozen times !
Old Jul 24, 2008 | 12:21 PM
Dmity Kiev's Avatar
Car: Firebird 91
Im read original chip (2732A) with universal reader and save it , also i have a police chip and trying to find difinitions , Also my friend is repair injection cars today he try to do some hints and car ran better now, but still have a problem: when im staying and pull full throttle shes fired up but wont burn the tires , only light tires tale on tarmac about 5-7 meters car with 300 hp cant be like this , when i run on the streen about 20 mph and do a full throtle she is fired up amazing and kickdown works great. My tranny is absolutely new with 2nd heavy duty stage from TRANSMISSION DEPOT , what it can be ? no detonation , no gasoline smell , engine works great at idle speed . car have posi 3.23 and now i use BM shifter cable with standart shifter becouse my cable is broken and i dont like BM shifter at all , car start running from 1st speed but i dont know from D or OD
Old Jul 24, 2008 | 12:44 PM
Ronny's Avatar
check tunerpro site for definitions...
Old Jul 25, 2008 | 04:14 PM
DM91RS's Avatar
Car: 91 RS
Try to post your bin on here so we can have a look........that link in the first post does not work for me.............
Old Jul 28, 2008 | 12:49 PM
Dmity Kiev's Avatar
Car: Firebird 91
here is the last version of my bin http://rapidshare.com/files/13312331...1074_.bin.html
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
Street Lethal
Aug 14, 2015 08:25 PM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
