TBI convertion
Old Aug 4, 2008 | 11:29 PM
Flip66's Avatar
TBI convertion
I am converting an 88 cutlass with a CCC to TBI from an 89 Chevy truck. When I started it the first time it started right up and ran smooth but the RPM was high and I had a vacuum leak between the adapter and intake. I took it apart to fix the leak at the same time I did the mod to the TBI that will let in more air. I put it all back together now it will barley start let alone run is they’re something I am missing?
Old Aug 5, 2008 | 12:13 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: TBI convertion
307 Oldsmobile with a 305/350 TBI setup on it?
Old Aug 5, 2008 | 10:17 AM
Flip66's Avatar
Re: TBI convertion
Sorry I should have said that No its a chevy 350 with mild RV cam. One more thing I checked the TPS volts it is from .4 low end to 4.0 WOT I can not get it any higher on the low end.
Old Aug 5, 2008 | 10:50 PM
Flip66's Avatar
Re: TBI convertion
I took 3 of the plugs out and they are black looks like from running to rich I did not check them before the swap so I dont know how long they have been like that. Anyone know how long it would take a plug to foul due to running rich? The TBI was only running for a few min not even long enough for the car to get hot so I am guessing they where that way before I started the convertion. Would that explaine why it ran with a vacuum leak it was leaning it out?
MustangBeater20
Oct 29, 2022 09:20 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
