what aluminum head options are for us LO3 guys
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
I have heard about the 113 L98 vette heads, and that they are a good choice because they have the same compression ratio. But what other options do we have? Thanks
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Re: what aluminum head options are for us LO3 guys
There's the TrickFlow Super 23 cylinder heads, those are the ones I'm looking at getting for my LO3.
http://store.summitracing.com/egnsea...115+4294867028
Those heads have a 56cc chamber so your compression ratio will go up. As far as I know the stock heads have a 58cc chamber.
Engine: LO3
Axle/Gears: 3.08
Sounds a little too expensive for what im wanting to put on a 305. Anything else?
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
port the hell out of ure heads ive been told several times u can get some pretty respectable numbers out of those heads when ported.
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Why you want aluminum?
The only budget oriented options would be 113 heads, the L98 heads, vortec heads, maybe patriot heads, or get 081 [305TPI] heads, or port what ya got. Everything else will be $$$. Vortec you need to get a different intake manifold to run though.
Engine: LO3
Axle/Gears: 3.08
it's been suggested to me to get aluminum because they are cheaper to port plus the weight saving. I also want to go get a cam that would push the limits of my stocker heads, i don't want to ride on the limit when i can have something that can take more then what i want to throw at it..
Car: 1992 Firebird
Engine: 350TBI
Basically unless you find a good deal, aluminum wont be cheap.
What cam are you going with? Whats your target whp?
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Ive got a set of aluminum 128 vette heads the only difference from 113 is they use the old style manifold but are still a center bolt head i got mine with a 5 angle valve job port polish also ti-retainers they were milled to 53cc they cost me 800
Engine: gone
Transmission: gone
Axle/Gears: gone
ellaborating on this are the only options for a smog legal cylinder head the edelbrocks?
Car: 87 Trans Am
Axle/Gears: Not enough
question, how much weight would one save on aluminum vs steel 305 heads.
Car: 1992 Firebird
Engine: 350TBI
