help rebuilding 305 engine
Old Aug 25, 2008 | 08:18 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
Axle/Gears: 3.42 posi
I have a 1990 camaro rs with a stock 305 tbi with a 3.42 posi rear. The engine has started to take a dump and rather than put in a 350 I have opted to restore her 305 with a few mods but I don't know where to start.she needs new heads because the stock ones are going as well as the head gaskets because she is overheating. I don't know where to start to get some new performance heads for her that will bolt right on. I was also thinking of switching to a carb which would mean a manifold switch as I understand. I also am looking for a 700r4. I have no where to start to find what I need. I want her to be fast but not insane.
Old Aug 25, 2008 | 10:44 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: help rebuilding 305 engine
Well you're on the TBI board so you're going to hear keep the TBI which I wholeheartedly agree with. I hate to say it but the search function works great. But if you just want a fairly quick TBI car without breaking the bank to much here's a list. If you're going to do a rebuild and you want to keep the stock stuff here's what you can do.
Get the heads rebuilt. Opt for a bowl blend and a three angle VJ with some back cut valves.
Know what power level you want. For a small upgrade, 1.6 roller tip rockers
You have many cam choices you can use but remember if you want to swap cams TUNING is a must. Here are some popular choices in the TBI world.Starting from smallest to largest.
L31 cam
88-89 L98 cam
93-95 Lt1 cam
PRODUCTION LT4 cam
ZZ4 cam
LT4 HOT CAM
Exhaust is an absolute must. Headers with a 3inch catback will do you very well.
Do you have an auto or a stick? If auto a popular choice is an 96+ 4.3 S10 converter. From what I believe they stall at about 2000 to 2200 depending on torque levels
you already have gears so you good to go on that part.
others will probably chime in but it really depends on what your end result will be.
Old Aug 25, 2008 | 10:48 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
maybe take into consideration a vortec setup. vortec heads and intake work great with tbi motors. some good cam selections were stated above.
Old Aug 26, 2008 | 04:23 AM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
Where can I find these vortec heads and manifold? What does everyone think about 4bbl tbi units?
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
