lt1 heads on 305?
Old Aug 28, 2008 | 04:45 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
Axle/Gears: 3.42 posi
lt1 heads on 305?
Will lt1 heads from a 95 vett fit on a stock 305 from a 1990 camaro? I need to know as soon as possible because they might go quickly. Please someone help me. All help appreciated
Old Aug 28, 2008 | 05:32 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: lt1 heads on 305?
As a direct bolt on No LT1 heads are reverse flow. With enuff money they will but not worth it.
Old Aug 28, 2008 | 05:56 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
dunno what to do. Some say it'll bolt right on since its one sbc to another.how would I make them work?
Old Aug 28, 2008 | 06:08 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
they WILL bolt right on but will not work....the water passages are not compatable and who ever says they are both small block chevys is an idiot so dont listen to them they are very similar and a few things can be swaped between the two (heads are not one such item) but there is a reason traditional small block chevys are called gen 1 motors and lt1s are gen 2 motors....they are not the same. dont waste ure time to get them to work requires alot of welding and machinework...youll spend about as much as u would on good aftermarket heads withought the performance.....
Old Aug 28, 2008 | 07:49 PM
3rdGenSkan's Avatar
Car: 90 camaro rs
Engine: LO3 305 tbi
What kind of heads will bolt right on and give my 305 much better performance
Old Aug 28, 2008 | 07:52 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
UM...ill let someone else field this one cause i dont care for 305s too much and dont really know what works good with them...but i have hears u can get good flow from lg4 heads if u just do sompe port work.....good luck but stay away from the LT1 parts...
Old Aug 29, 2008 | 10:34 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
World products makes a set of aftermarket 305 heads, but they arent that great from what ive read. 113 aluminum corvette heads arent exactly aftermarket but they are a good upgrade, 58cc chambers to boot which will not make you lose compression either
Old Aug 29, 2008 | 11:17 AM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Unless you put a little bigger cam in there I don't think you'll really gain much of anything. If you were doing a cam swap and putting in an LT1 cam ( I assume they work well with L03's) then I would recommend the 083 heads.
I am in the process of doing that very thing, but in my 350 TBI. NEW RHS heads (083/217 style) 2.02 intake with 1.60 exhaust, 76cc chambers and roller rockers along with a Comp Cams 8-304-8 cam. Now we are talking more power and more fun, lol. These heads on your L03 (305) are too much so you need to ask...
The heads I got off eBay from J&C Enterprises for $499. They are NEW. 1-800-266-5599. You may want to give him a call and ask if he has similar heads for an L03.
Here's the description of the heads.
76 CC Combustion chamber 083 / 217 casting style high flow design
Heads are assembled with new 2.02 One piece stainless steel intake valves
Heads are assembled with new 1.60 One piece stainless steel exhaust valves
Heads are assembled with new 3/8 screw-in-studs and guide plates
Heads are assembled with new stamp steel valve spring retainers
Heads are assembled with hardened valve keepers
Heads are assembled with new. 550 lift springs
Heads are assembled with new valve seals
Heads are complete and ready to install
Again, I don't know much about the L03/305 other than how to take one out and replace it with a 350, LMAO!!! Also, you can contact Brian Harris at tbichips.com or tpichips.com. This man is honest, friendly and a wealth of knowledge.
Old Aug 29, 2008 | 11:25 AM
dctrumpet's Avatar
Check out these heads on eBay. Not sure if they are the best for your setup, but it's something to look into.
http://cgi.ebay.com/ebaymotors/305-3...mZ260280123193
Old Aug 29, 2008 | 11:26 AM
Ronny's Avatar
World SR 58cc chamber 2.02 intake 1.60 ext $759 pair summit
Dart Iron Eagle 64cc same $1007
or maybe the best idea GM Vortec 1.94/1.50 $520 a pair BUT require a Vortec Manifold $145
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
