What next for my LO3?
Old Sep 4, 2008 | 06:19 AM
SMKNTRS's Avatar
I have Hedman Headers, Random Tech 3" exhaust, 160 thermo, fan switch, Poly tran mount, TPI fuel pump and am running the 1/4 mile at 16.04 @ 84.59mph. What should I do next? I'm not real happy with my 1/4 time but I improved .4 over stock.
Old Sep 4, 2008 | 11:43 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Re: What next for my LO3?
lt1 cam...best bang for the buck..
gears possibly? 3.42's
Old Sep 4, 2008 | 12:35 PM
SMKNTRS's Avatar
I have a WS6 rear end to put in soon, it has posi, disc brakes and 3.23 gears. and I have the aluminum driveshaft for it too.
Old Sep 4, 2008 | 06:52 PM
Car: 1991 Z28
Engine: SBC
a 3.42 gear would be your best power gear but 3.23 is a good gear too so i would say your set on that end. I would say lt1 cam is next or invest in some tuning stuff, these cars really wake up after a good tune not to mention you can squeeze some good mileage out of them as well.
Old Sep 4, 2008 | 08:00 PM
SMKNTRS's Avatar
By a good tune I assume you mean getting a chip burned? Thanks
Old Sep 4, 2008 | 08:04 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
well 3.23s dropped me down a bit i think it was 4 tenths but really it was the adding posi that really help my times go down
are you still useing the stock aircleaner? or running open element
also mod your fpr to be adjustible and bump it up a little
mine ran best with 16 psi fp and timing @ 4 advanced
Old Sep 4, 2008 | 08:11 PM
SMKNTRS's Avatar
Yeah, I've been wanting to go open element. I'd like to get comfortable with doing the timing but even after reading articles I think I will need someone to hold my hand through it haha
Old Sep 4, 2008 | 08:13 PM
Car: 1991 camaro RS
timing is so simple just get a timing light and distributor wrench
and you turn it to adjust timing
SMKNTRS's Avatar
After doing some research I thought a changing a cam was a cheap but time consuming mod, but after adding it up its like 200-300 before shipping and text.
Old Sep 4, 2008 | 08:15 PM
Car: 1991 camaro RS
there talking about useing a used lt1 cam can be had for 20-100 bucks shipped normaly
SMKNTRS's Avatar
Eh, what could it hurt to try, gotta be easier than pulling the driver side exhaust manifold haha
What about the spring ($60) timing chain ($50) and gaskets galore ($50-80)
Old Sep 4, 2008 | 08:22 PM
Car: 1991 camaro RS
intake gaskets water pump gaskets and timing cover gasket really thats all you should need gasket wise but its a good time to also replace the rubber valve cover gaskets
Old Sep 4, 2008 | 09:05 PM
rebo880's Avatar
Car: alot
Engine: a little one
Transmission: a slipping one
I'd say A trans go trans pak fo rthat slush box and then a custum chip
Old Sep 5, 2008 | 01:43 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
https://www.thirdgen.org/forums/tbi/...-synopsis.html
I plan on adding more to it but there you go. Plus all the other stickies at the top of the board.
Plus try pulling some weight out of the car. BELIEVE me it helps. My car weighs 2900 pounds without me and a half a tank of gas. Even now my car pulls quite nicely.
Old Sep 5, 2008 | 05:55 AM
SMKNTRS's Avatar
I think I may make doing the LT1 cam my winter project, along with replacing both my fenders, fixing my ground effects and repainting my headers and rear bumper.
Ah.. so much work to be done.
On another note I found a guy selling a LO5 engine for under $400 locally, but I was reading posts the other day that taking the LO5 route isn't a good idea now for a daily driver.
Old Sep 5, 2008 | 12:39 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Whats wrong with the L05 in a daily driver? Its an extremely mild engine just like the L03. For 400$ as long as it runs with no major problems, id jump on it, get that, a nice cam, some good heads. And you can very easily get into the 13sec range.
Old Sep 5, 2008 | 01:41 PM
SMKNTRS's Avatar
I found that its the truck LO5, so no roller cam
anesthes
Sep 21, 2015 10:24 AM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
JPrevost
Carburetors
Nov 12, 2001 06:28 PM
NHcamaro
Jul 31, 2001 01:35 PM
