Open Element Air Cleaner ?'s
Old Sep 7, 2008 | 03:26 PM
lilwill355's Avatar
Car: 1991 Camaro
Alright....today i had some time on my hand. So i went to advance auto parts and bought an "Edelbrock 1221" air cleaner for 20 dollars. I read the articles on how to install the air cleaner but i had some questions and also it didnt fit. The screw isnt long enough so for the time being i just flipped it over the top(how much would it cost to get a longer one?). And i was wondering what was an air cleaner that doesnt require to buy a longer screw that other 3rd gen people have gone with? because it would probably be cheaper if i buy a different one
But what do you do with the factory breather filter? should i buy a chrome after market one. and should i cover the hole in the exhaust?(where the fixable hose was attached to) let me know thanks
But it was a really easy and fast install
Old Sep 7, 2008 | 04:34 PM
lilwill355's Avatar
Car: 1991 Camaro
Re: Open Element Air Cleaner ?'s
never mind.....figured it out. You can make the screw with the wing longer by unscrewed it a little bit. fits perfect. Sounds good but no real gains. I call it my Eco-V8. "camaro gone green"
Old Sep 7, 2008 | 08:11 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
that flexible pipe is called a heat stove. when the car is cold it opens a valve and channels heated air off the exhaust through the air cleaner to make it behave a little better. just set it on the shelf and forget about it.
Old Sep 9, 2008 | 01:50 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
you modify your Open Element for your sensor or did u just tie it up ?
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
