1992 305 TBI Trans Am Blink Codes Please...
Old Oct 17, 2008 | 01:27 PM
BustaZz's Avatar
Please help me , Anyone can give me all Blink Codes for my birdy...
Thank You !
Old Oct 18, 2008 | 06:17 AM
BustaZz's Avatar
Re: 1992 305 TBI Trans Am Blink Codes Please...
OMG..... Tank you "mate`s" .... Thank you for helping..... NO COMENT
Old Oct 18, 2008 | 06:50 AM
Icarus 402001's Avatar
Car: 92RS
SEARCH!
Old Oct 20, 2008 | 02:09 PM
Ronny's Avatar
What is the sequence of blinks? I have a Haynes that lists them.
Old Oct 23, 2008 | 07:57 AM
BustaZz's Avatar
Can you give me yours codes ?
Old Oct 23, 2008 | 09:08 AM
Ronny's Avatar
Pull the codes by shorting the ALDL and report back here. there are maybe 25 or so listed in haynes manual. if you like i can fax. no scanner here. OR go to local autozone checker napa whatever and they will scan for free!
Old Oct 23, 2008 | 09:46 AM
FUNIROC's Avatar
Car: 1989 IROC
Here see if this will help.
While sitting in the driver's seat, you need to connect the 2 pins in the top row on the right side of the connector with a wire or paper clip, and turn the ignition on without starting the engine.
For GM domestic vehicles made before 1995, the diagnostic connector is located under the dash panel by the driver side. To get the check engine codes to flash in your dash panel, use a jumper wire or a paper clip and connect terminals A and B of the diagnostic connector. Turn your ignition key on with engine off and the codes should start to blink. All codes should start with code 12 which is one long flash followed by 2 short flashes. This code 12 means the diagnostic system is normal and will repeat itself continuously if there are no trouble codes. Otherwise, code 12 will flash 3 times before flashing the fault codes.
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
