looking to buy 305 S/R torquer heads, are they a direct bolt on?
Old Nov 4, 2008 | 06:10 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
All i want is a nice step up from my stock heads, ive read the the S/R torquers are a good way to go.
My question, obviously there are several world S/R heads, which ones will be the most direct bolt on head for my car. Is there any modifications needed or are these a bolt on and go? Part numbers and where to buy these heads are welcomed!
My plans for the motor only include these heads, eld. intake, and cam. just to give you the idea of what extent i plan on building my motor.
Old Nov 4, 2008 | 09:29 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
Re: looking to buy 305 S/R torquer heads, are they a direct bolt on?
good question, subscribed for answer.
Old Nov 4, 2008 | 10:26 PM
ThEWhitebirD's Avatar
Car: 1989 Pontiac Firebird
Engine: 305 Tbi w/lt4 hot cam
Axle/Gears: torsen 3.42
Im sure others will say go with the vortec heads and get the vortec intake to go with it. But if you want a direct bolt up the world heads are not bad..
I got the world heads(for the same reason), they do for the most part bolt up. you will need adapter bushings for the fan switch in the pass. head and the dash temp sender in the driver side head. the sensors have a smaller thread than the world heads. they also have the same 58cc chamber as stock but use a 350 head gasket, not a big deal though.
Im happy with them but they are heavy like others have said.. get them worked over and ported before you put them in.
heres a link they dont go under the name torquer any more but its the same head http://www.jegs.com/i/World+Products...750-1/10002/-1 it even has the bolt hole angle for the 87-up intakes.
what kind of intake do u plan on using? cam?
Old Nov 5, 2008 | 05:04 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
Thanks,
I really dont mind that they are heavier then say the alum. heads. Im not into racing so much that weight is a factor for me.
I already have a preformance T/B and a Edelbrock RPM intake, im waiting to make up my mind on heads so i can have everything port matched before i install it all. Im pretty sure im going with the S/R torquers so i hope to have the here by Christmas
As for a cam I was thinking about going with a 210 / 220, .480 / .480 112 LSA cam from comp cams. Im unsure because i don't know much about cams so ill do some more research on that.
Old Nov 6, 2008 | 12:26 PM
Ronny's Avatar
world comes in a smaller chamber of 58cc. Is that not what a 305 needs?
Old Nov 6, 2008 | 01:26 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
I believe 305 heads tend to be 58cc.
Old Nov 6, 2008 | 02:03 PM
greg320's Avatar
Car: 1992 Camaro Z28 Convertible
Engine: L98 TPI
Axle/Gears: GM 10 bolt, 3.42GM
Hi Guys,
I am doing the same, just want to make the L03 a little more fun. Just want a bunch of bolt ons till I can get a nice 350. The World heads are what I am getting, was planning the Turbo-city high flow throttle body. does anyone have suggestions on intake and cam. Again part numbers would be very helpful. Also I am planning on keeping my stock hood, so I need this stuff to fit. Thanks
Old Nov 6, 2008 | 10:43 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I know I ***** this thread out alot but I think it REALLY helps with the newbies. here you go.
https://www.thirdgen.org/forums/tbi/...-synopsis.html
Old Nov 7, 2008 | 10:00 AM
Doc_G's Avatar
Car: 87 Trans Am
Thats ok RF, someone has to do it and atleast your not a butthead about it.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
MENINBLK
Aug 5, 2015 11:58 PM
