350tbi on 305
Car: 91 Camaro RS
Engine: 305 tbi
350tbi on 305
so i think the diaphram on my tbi junked on me and i have a tbi from a 350 lying around should i be able to swap this no problems?
Car: check
Engine: check
Transmission: check
Re: 350tbi on 305
Not really. The injectors in the 350 TBI unit are larger which will cause the 305 to run too rich. However, if you are able to tune the setup then no problem.
Or, use the 305 injectors in the 350 TBI, or swap the 350 TBI fuel pressure regulator onto the 305 TBI unit. Note that you may need a new gasket when swapping the injectors.
RBob.
RBob.
