Code 42 normal when setting timing w/ EST disconnected?
Old Dec 3, 2008 | 09:06 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Is it normal to get a code 42 stored after very recently running a 1988 TBI for several minutes w/ the EST wire disconnected to set the timing? Or does the code 42 indicate there is something wrong w/ the ignition module or its wiring?
STeve
Old Dec 3, 2008 | 10:58 AM
pvollman's Avatar
Car: 1986 Trans Am/2002 Trans Am
Engine: 305 V8 and LS1
Axle/Gears: Stock
Re: Code 42 normal when setting timing w/ EST disconnected?
Yeah it's normal...due to setting the timing. Just clear it with a scanner, or unplug the ECM fuse (wait 30 seconds or so), if that doesn't work the negative cable will need to be dropped from the battery (wait 30 seconds or so) then reinstall.
Old Dec 3, 2008 | 11:39 AM
Car: 2000 BMW M5
ok great thanks
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
