tbi backfire issue could use some advice
Old Dec 3, 2008 | 11:41 PM
zchevy2's Avatar
Car: 82 camaro
Engine: 383 strocker
Transmission: th350
I have recently finished my 355 it has world heads 2.02/1.6, an edelbrock 3702 cam, 3704 intake, shorty headers and 1.5 roller rockers.
The timing is set to 6*advanced it idles fine but at highway speeds it has a stumble and pops through the tb, rpms drop 1-200 it happens 3 or 4 times then comes out of it and runs fine for a minute of two and happens again.
It has a stock tune is that the problem? i dont want to hurt the motor i have a ton of time and money in it so any experienced advice would be great!
Old Dec 4, 2008 | 01:27 AM
zchevy2's Avatar
Car: 82 camaro
Transmission: th350
Re: tbi backfire issue could use some advice
I pulled the plugs and they were very lean but my afpr is maxed out how do i get more fuel with out getting bigger injectors? Would a chip solve my problems
Old Dec 4, 2008 | 09:59 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Check fuel pressure! How much fuel pressure are running? Bigger injectors will not help you if you do not have adequate fuel pressure and volume...
//RF
Old Dec 4, 2008 | 12:16 PM
Ronny's Avatar
What you are experiencing is normal for an untuned modded engine. I experienced exact same day one. Lean backfire. I dont think the timing table(truck) is at issue. I would leave it as is for now. Can always change "idle" timing later as that may need some change.
As was stated your fuel pump may not be up to task. Did you add a FP gauge. I would do that for sure. What size injectors at what FP? You can up FP temporarily and see how engine responds. I would consider getting a datalog ALDL cable ASAP and load winALDL and check the BLMs. you are most likely gonna see very high BLM. Seperately the AE or pumpshot will need to be increased considerably. That is seat of pants unless you invest in WB. It goes without saying no WOT
Old Dec 4, 2008 | 02:56 PM
zchevy2's Avatar
Car: 82 camaro
Transmission: th350
I have 55 pound injectors but i dont have a fp gauge yet it is still on order im guessing that my fp is 15-17 psi with the regulator turned all the way.
ill go borrow a fp gauge from a buddy get to check it for sure.
Im looking for a quick but not long term fix just so it is safe to drive it im going back to work in a few weeks and dont really have time to learn how to data log, though i would like to, ive looked in to it alot but it seems like it takes alot time to get started.
Old Dec 4, 2008 | 03:04 PM
Ronny's Avatar
I dont think one should max the FP regulator. Maybe 80%. I maxed mine with a TPI pump and blew a new reg gasket. Maybe the stock TBI pump it wont be an issue. There is a nice spring that will give higher FP than stock at topdownsolutions. Issue is whether the stock FP will deliver?
Old Dec 4, 2008 | 05:57 PM
zchevy2's Avatar
Car: 82 camaro
Transmission: th350
what fp would u recommend, also would a chip with better fuel table help, im going with a mail order chip for now does anyone believe that the chip will make a difference, i dont have time to make my own, so any recommendation on a chip?
Old Dec 4, 2008 | 07:06 PM
RFmaster's Avatar
Car: 75 Beast
Measure and verify your fuel pressure. Without knowing what your actual FP ordering a chip is meaningless. 55lb injectors can supply adequate amount of fuel to a modified engine at higher pressure - hence you do not need bigger injectors.
//RF
Old Dec 11, 2008 | 04:08 PM
zchevy2's Avatar
Car: 82 camaro
Transmission: th350
so i finally got my fp gauge it says i have 16 psi at idle i also noticed that the headers melted the o2 sensor wire could that be a problem fp seems adequate but it still doesnt run very well in gear but in idle it revs fine no backfire any ideas (map sensor, o2, idle air, tps)
Old Dec 11, 2008 | 04:31 PM
Ronny's Avatar
replace the 02 sensor and re-exam wire route. Same on starter wires.
After that pull codes.
Old Dec 12, 2008 | 03:23 AM
zchevy2's Avatar
Car: 82 camaro
Transmission: th350
I checked all my wire everything looks good, i fix the o2 sensor, and the computer has no codes. I put in my 255lph fuel pump today and im waiting on a stiffer spring for the afpr what kind of fp can i run before the injectors go static.
After this im out of ideas, it runs like xxxx, could i possibly need bigger injectors it just seems like it is starving for fuel, could the map sensor be bad? just some thoughts but im no expert.
Old Dec 13, 2008 | 11:04 PM
zchevy2's Avatar
Car: 82 camaro
Transmission: th350
So i solved my problem I set up my base timing to 14* and it cleared right up, runs great, i want to thank everyone for the help. i think this is the most knowledgeable car site on the web.
xkingcodex
Feb 12, 2020 07:43 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
