fuel filter question
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
What all do you have to do to relieve the pressure in the fuel lines for a TBI engine to change the fuel filter? I have been told to first take the gas cap off to take the pressure from the tank, but is this the only thing that has to be done or is there more to it? (I'm sure this question has been ask before but I couldnt find anything using the search button)
Car: 1991 Z28
Engine: SBC
Re: fuel filter question
you could pull the fuel pump fuse or undo the relay and let it run until it stalls..but tbi isnt under much pressure to begin with so. Let alone i believe it doesnt hold pressure after you shut it down? I could be wrong on that part of it though..
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
when i did my fuel filter there was fuel coming out from the line going to the tank the whole time. i still don't know why the F it was doing that. and yes i did remove the filler cap
maybe i should have removed all the pressure..
but, since it took me rather long to remove the filter and install the new part, i would roughly guess that 5 gallons poured down, i caught it all in a container and poured it back in the tank after doing the filter
maybe i should have removed all the pressure.. but, since it took me rather long to remove the filter and install the new part, i would roughly guess that 5 gallons poured down, i caught it all in a container and poured it back in the tank after doing the filter
Car: check
Engine: check
Transmission: check
On a TBI setup the fuel pump pressure bleeds off quickly. It is a good idea to loosen the gas cap to relieve any pressure build up in the fuel tank. The real problem is that the fuel siphons out once the line at the filter has been opened.
With the filter lower then the tank this is why the fuel just keeps on draining out. Not much can be done about this except to have the fuel level as low are you dare (on 'E') for the filter change.
Don't forget that there is an O-ring on each fitting and the filter is directional. Arrow points toward the driveshaft.
RBob.
RBob.
OK thanks for all the help I think I'll run it down to a quarter tank before i try it, and I'll have something ready to catch the fuel in.
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
As long as you got your new filter under the car with you, so you can swap it quickly you shouldn't have to worry to much gas leaking out. Replaced my fuel filter with a full tank and lost maybe 1/4 gal.
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
I haven't done my fuel filter yet, so maybe I'm missing something, but couldn't you just buy a rubber plug or cap like you would for a vaccum line? If its not pressurized it seem like that should be enough to stop the leak.
Car: 88 Camaro
Engine: 305 TBI
I'm pretty sure you could. But its not necessary.
Engine: 350 TBI
Even if you don't mind losing a little gas, why make a mess in the driveway? I'd have some vaccum plugs handy, or at least a bucket, although it sounds like some people are losing more than a bucket full.
1992 Trans Am
May 10, 2023 07:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
