"Crossfire" Kickin my butt!
Old Jan 19, 2009 | 03:58 PM
Twoelouie1952's Avatar
Car: 83 Z28 "CrossFire"
Engine: 305 cid
Transmission: 700 R4
Axle/Gears: 323
Hopefully somebody out there is a "Crossfire Wizard" cause I sure can't seem to find one locally in Denver!
Mine waz runnin GREAT for years and the past 6 months its been "spittin" back thru the throttle bodies and blowin the vacuum lines off the back of the backside of the throttle bodies. Its runnin like CRAP and buildin up BLACK carbon inside the bowls !! Any ideas
Sure gonna be embarrassed if its only a bad PCV valve or I was thinkin a couple of "flat " cam lobes ???? Any other ideas??
I wanna keep the "Crossfire" set up as I have the functional "opening" hood. HALP!!!!
Old Jan 19, 2009 | 04:02 PM
Twin_Turbo's Avatar
Re: "Crossfire" Kickin my butt!
First thing to do on a fuel injected car is check the fuel pressure
Without any info I can tell you the first thing I would check besides fuel pressure is the CTS in the intake manifold, if it's the old mushroom type, toss it and replace it with a weatherpack type
Old Jan 19, 2009 | 04:09 PM
Engine: 305 cid
Axle/Gears: 323
Forgive my ignorance......CTS???? That term doesn't ring any bells.
I was gonna ask for your phone #...but, you're not even close to bein "local" .Sure do apperciate the help.
Old Jan 19, 2009 | 04:18 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Maybe the throttle bodies need to be rebuilt? How many miles are on the motor? Could be injectors maybe or fuel pump, or fuel pressure regulator. Could be something like TPS or IAC if they have those things on the crossfire cars [im speaking coming from the TBI world]
Theres just a heck of a lot of things it could be.
Old Jan 19, 2009 | 10:17 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Like everyone has said, it could be a number of things. Check fuel pressure, injector spray pattern, regulators.....
They are known for leaky throttle shafts as well.
If you need overhaul gasket/o-ring kits, IAC Valves, etc let me know.
Veaceonee
Sep 29, 2016 08:15 PM
Fox118
Sep 12, 2015 09:29 PM
ambainb
Aug 29, 2015 12:43 AM
Ovrclck350
Dec 2, 2001 02:41 PM
82T/A powah
Theoretical and Street Racing
Nov 28, 2001 11:31 PM
