Map sensor question
Old Jan 24, 2009 | 07:55 PM
chevyracer8262's Avatar
Map sensor question
I have a few questions i was wandering if you may can help me out. Will 15" of vacuum @1000 rpm be enough vacuum for the map sensor to function properly? I'm building me another engine for my truck and I'm trying to decide on a good hydraulic cam for my it. So far what I have is a .030" 3970010 350 block, trw forged .220" dome floater pistons, ported 993 open chamber heads which should yeild 10.7:1 comp, eagle 5.7" forged ibeam rods, 1.5/1.6" aluminum roller rockers with a throttle body with all the ultimate tbi mods. I'm just trying to decide on the cam.
Old Jan 24, 2009 | 08:31 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Map sensor question
I think that your question should be phrased somewhat differently - will 15" in-Hg at 1000 RPM (I presume idle) tolerated by a stock TBI ECM tune. Map sensor is just that - it will provide equivalent voltage back to ECM. What ECM does with this input is another story all together.
The answer is probably no or you may see very marginal idle performance with a stock tune (I assume that you have 7747 ECM with ASDU or ASDZ tune). However, not all is lost as your ECM's can be tuned to accommodate your engine particulars - it will involve some tuning effort on your part.
//RF
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
