Holley throttle body
Old Aug 25, 2003 | 12:24 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I posted a thread a while back asking about the part # I need for my camaro with a 350 and I was told I need a 502-6 well the guy I am buying it from said that its a #80405 I figure thats not the actual part# because he doesnt know much about it so I was wondering if anyone knows what unit this is?Also I have hears about people haveing problems wiring the injectors up ,I was wondering if anyone could help explain that to me also . Thanks guys I appreciate it.
Old Aug 25, 2003 | 12:34 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Straight from Holley
I asked the same question of the Holley tech staff. Here is their response:
"The 80405 is a 502-6 throttle body for a 87-89 chevy 350 truck. The 80374 is a 670 replacement throttle body for our projection application. Thanks Jessie"
Best-
S-D
Old Aug 25, 2003 | 12:38 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Alright thats what I need , I appreciate it man , Now I am going to buy it all I need to know is the Question about the wiring . Could I just plug My harness into there injectors?
Old Aug 25, 2003 | 02:52 PM
Car: 1991 RS
I believe that the TPS connector is different. You may want to do a search to verify that.
I can tell you that the TPS on my 87 TBI pickup truck is different than the TPS sensor connector for my 1991 Camaro TBI.
S-D
Old Jan 7, 2009 | 06:35 PM
90poc's Avatar
Car: 1990 Firebird
Engine: '89 cubevan 350
Axle/Gears: 98SS 3.42
Re: Holley throttle body
S-D
what sized engines?
Old Jan 9, 2009 | 03:40 PM
Ronny's Avatar
If the GM connector matches the Holley injectors I dont see why not. The Holley TPS may need a holley TPS pigtail or another that mates.
Old Jan 11, 2009 | 01:30 PM
IROC-Z_Racing's Avatar
Car: 89 IROC-Z28
Engine: LS1 "ASA"
I'm looking at throttle body spacers for my LO3 TBI for my '89 IROC Camaro. If I look under the camaro parts list in any parts store or online, the only thing that comes up is the TPI spacers, but if I look under a 1989 Chevy 305 5.0L then I could get a spacer. Is the throttle body on the truck the same as the throttle body on my camaro? If so then I could use the throttle body spacer, right?
Thanks,
- Justin
Old Jan 14, 2009 | 10:45 PM
schalk35's Avatar
Car: 92 camaro rs 25th anniversary
Engine: l03
Axle/Gears: 2.73 10 bolt
they both are the same.. I have a TBI spacer that is from Trans Dept. You can google them and find out more..
Old Jan 15, 2009 | 05:32 AM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
One more question, obviously I would need to change the intake to compensate for the increased flow, but would a 454 TBI work, as far as sensor hook-up, and fitment to my 305 motor?
Old Jan 15, 2009 | 09:44 AM
Ronny's Avatar
I hate to rain on your parade but why are you considering a 7.4L TBI unit? Unless you have mods that require an increase in flow(25% + or -)? Regardless 7.4L TBI will require significant ECM tuning. I thought the TB itself is same size for 305/350. They do vary in inj size. Stock TB is adequate for stock or mild mods.
Old Jan 24, 2009 | 10:33 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Squeeze the most out of your stock TBI unit. Almost done with mine.
Took off the Raised ridges, bowled the edges, and grind'd the throttle shafts so far.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
