Best intake manifold for my motor
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
I currently have the Edelbrock 3704, but im going to be adding my super charger to my car and I figure I might as well get the best manifold I can.
heads are 113 vette heads, cam is comp xfi268, supercharger is a whipple 6psi
I dont have EGR
http://www.jegs.com/i/Trans+Dapt/969/2210/10002/-1
That the adapter I need?
And thanks for any suggestions.
I dont have EGR
Re: Best intake manifold for my motor
Yes that is a good adapter! Its the same one ive been using for 2 years and no problems. As for intake manifold I would think that a good single plane would be the way to go!! Lots of choices out there Holley/Edelbrock/Weiand etc. I would assume that the whipple is a side mount style?? You may want to change the cam to a blower style while your at it?? Just my thoughts. How is the XFI268 cam?? How was it to tune etc. Just wondering??
Car: 1992 Firebird
Engine: 350TBI
The supercharger is a top mount, it has a couple adapter plates that allow it to use the TBI bolts. Its a TBI supercharger they made a number of years ago.
The XFI268 is actually the cam comp recommended for me to use with the supercharger. I had a dyno tune on it, and it runs pretty good now. But if you have wideband, its a very streetable cam and shouldent be hard to tune.
Any particular features I should look for in a single plane? Maybe a couple recommendations I can look at?
I would look for a good quality single plane that has a decent amount of extension with the plenum dividers. You should get a more consistant fuel mixture that way. Also something with a little bit of roughness to the plenum floor. It helps to atomize the fuel, even though you will be forcing it through anyway. I think last time that I looked the edelbrock victor jr was a good choice as well as a weiand. Just my opinion though!!! So you are currently running that cam with a good tune then?? I do have a good WBo2 and do my own tuning. I was planning on a head swap this summer along with that cam possibly. Just wanted to know what it ran like etc. Thanks
Car: 1992 Firebird
Engine: 350TBI
Alright thanks for the tips.
And if the comp cams xfi268 suites your application, go for it. I have no problems with it, in fact I wish I maybe went even bigger, lol.
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
mind if i ask what results you got on the latest dyno pull? i remember you had some spark issues right? i thought you were using the LT4 cam though.
are you running the s/c on the stock bottom end?
Weiand make a low profile single plane called Xcellerator. I would suggest you look at it. you will need a 2 bar MAP sensor. I am sure you know that. And an ECU that can handle boost. Or one can use a fuel management unit(FMU) that may have been used for TBI when that product was developed in lieu of a correct ECU. that is not the best option.
A VAFPR is suggested as well. Aeromotive is a good choice.
Car: 1992 Firebird
Engine: 350TBI
I use the xfi268 cam and have LT4 springs on the heads.
It made 195hp/300tq with the incorrect spark plugs. I plan on going back to the dyno as soon as I get some money to see what I have now. My friend said I should easily see 20 more horsepower with the correct plugs, the ones I had in there barely got inside of the head, the threads were too short.
I have an aeromotive VAFPR. Not sure about the other stuff.
The supercharger just had a Whipple chip for the ECU, that was all it came with.
I will check out the Xcellerator.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I'm going for the Performer RPM myself. I have been researching it for awhile now. Might be something worth looking into.
Car: 1992 Firebird
Engine: 350TBI
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
