700R4 QUESTION
Old Feb 9, 2009 | 07:04 PM
williambrown78's Avatar
700R4 QUESTION
I bought a 92 camaro rs tbi car with no motor or trans.I pulled the 350 ans 700r4 trans out of my 87 camaro.It has a speedo cable set up but the car is set-up for electic speedo.I'm goin to use the tbi that came with the car is there a converter kit that will send signal for ecm and speedo?Or is it just better to find a newer trans?Thanks for any help you can give
Old Feb 9, 2009 | 08:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 700R4 QUESTION
You should be able to get a VSS for a '90 to '92 Camaro or Firebird and install it into the transmission. Both the cable and electronic speedo setups use the gears (driven and drive) within the trans. Just be sure to get one for the 700R4, not the T5. And the correct gears for the rear ratio.
Check over on the transmission board. IIRC the sticky's up top have additional information on the required trans gears.
RBob.
Old Feb 10, 2009 | 07:45 AM
Re: 700R4 QUESTION
thanks alot thats what i needed to know
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
