TBI Woes
Old Feb 16, 2009 | 01:09 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
TBI Woes
So like the title says, my TBI is making me say WOa!
Car was running pretty good. Slapped on my modded TBI united that i had dremeled down, shined up to looking brand new, put back on the 1/2 inch gasket spacer between manifold, put 2 in stead of one gaskets on the pod.
Low and behold the lever unit that my TV cable, Throttle cable ect hooked onto was different "i got the tbi unit from the yard with a intake manifold"
So I take my original and mod it to so
Think I did a kick *** job on it, even did the risky shafts to, looks like it was made this way.
Anyways, I have like a major loss in power, only difference is the mods I did and the second gasket to the injector pod base.
When i slam it, rpms jump you, it sounds like its going but they just hang and hang there and slowly go up, and when it shifts it hits alot harder now,
It has drasticaly increased my 0-60 time
Could this be my TV cable unadjusted ? Could the spacer in the pod be causing this? Could I be getting to much air now and not enough fuel ?
Any thoughts appriciated. Its raining outside so im bored and looking to find some enlightenment for when it stops!
Ty
Old Feb 16, 2009 | 01:36 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Re: TBI Woes
Start spraying some starting fluid all over to check for vacuum leaks first. Are you using a different FPR? Check fuel pressure.
Don't drive it until you get kick down working correctly. I wasted a few trannies this way.
Looks good, but the new one is obviously from a truck or something other than f-body. You might have different injectors unless you are using the old ones.
How is it idling?
Old Feb 16, 2009 | 01:42 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: TBI Woes
I'll be honest with you. Get rid of the spacer between the manifold and TBI. NOT one person can prove to me that there is any gain or benefit to using it.
Last fall i posted a thread showing the dyno results that several good friends did with their spacers. Causes more crap than what they're worth.
Some will argue with me, but those who do argue with me have yet to show pre and post dyno results.
Low end torque is slightly increased......
Old Feb 16, 2009 | 04:39 PM
90c350's Avatar
Re: TBI Woes
Vacume leaks maybe?? Have you checked to see if you are still getting WOT with the spacer installed?? Or with the modded tbi? Its possible that you are not getting full throttle do to the spacer or different tbi unit.
Old Feb 16, 2009 | 08:28 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: TBI Woes
Will not having the TV cable adjusted correctly screw your Tranny up?
Old Feb 16, 2009 | 09:11 PM
90c350's Avatar
Re: TBI Woes
Absolutley!!!!!!
Old Feb 16, 2009 | 09:21 PM
327Chevy's Avatar
Re: TBI Woes
Like they said, check the TV adjustment right away.
Also, with the engine turned off, have your wife/girlfriend floor it and then you look down into the TBI unit to make sure the throttles are opening all the way.
Also, how about a pic once you got the accelerator and the cruise connected? Just to make sure.
Old Feb 16, 2009 | 09:50 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Re: TBI Woes
Edelbrock and others make adjustable throttle linkages. I used one when going to a vortec manifold. Actually, in the end I used the stock one modified with one piece off the adjustable for the cruise. But you got a auto which adds one more cable to the equation.
Ditto for checking for full throttle, remove the spacer. Also, need to get your IAC counts to 5-10 when at idle and fully warmed up. From my experience, this will mess with your fueling quite a bit. Do some searches on how to do this.
Hard to tell from photo, but looks like the idle set screw is out quite a bit.
Old Feb 16, 2009 | 11:22 PM
89rs454's Avatar
Car: 1989 SS
Re: TBI Woes
Originally Posted by 90c350
Absolutley!!!!!!
I Guess i do not have to Absolutely worry about it. I have a turbo 350.
Old Feb 18, 2009 | 06:25 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Re: TBI Woes
The two trannies I trashed by not having the TV cable hooked up was a TH-350 on my old Monte.
Old Feb 18, 2009 | 06:33 PM
89rs454's Avatar
Car: 1989 SS
Re: TBI Woes
My turbo 350 does not have a TVcable
Old Feb 18, 2009 | 07:43 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
Played with the TV cable today, did nothing but make my shifts way off, now I gotta tweak that lol.
I will pull the gaskets off the injector pod, the 1/4 inch gasket at the base of the TBI was the one I was using before,
Will post back after the injector gasket gets removed, I believe the butterfly's were opening all the way "was checking tv cable, and such"
Thanks for all your posts so far !
PS, Car runs fine, cept when you smash the pedel if feels like im pulling another car behind me lol
Old Feb 20, 2009 | 12:54 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Re: TBI Woes
The only reason you would not have a TV is if you had a manual or reverse manual valve body. Otherwise the trans does not have a way to determine when to downshift or lock converter. Some trannies had a vacuum reference as well. Been a long time since I had an auto.
Old Feb 20, 2009 | 12:59 PM
89rs454's Avatar
Car: 1989 SS
Re: TBI Woes
Exactly the turbo 350 has a vacuum hose to determine gear shifts and downshifts.
Old Feb 21, 2009 | 06:44 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
I had to put back on my space for the Open air element which was used for the stock filter causing my tv cable to bend at like 60* So shifts are good still no power
Gonna take off the injector spacer gasket, and check for vacuum leaks, and double check the TBI-manifold gasket for alignment.
After like 3 grand the engine seems to get quiet at WOT and sounds like it wants to pop :/
Will post up after I fiddle with it here in a hour or so.
Old Feb 21, 2009 | 11:14 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
I took off the gasket tbi - manifold and put on a really thin one, nothing blocking fuel going down, took off the pod spacer as well, took it for a drive, still nothing, crap :/
Old Feb 21, 2009 | 11:17 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
Now I got this High pitch noise coming from the front left, it kinda goes away with the gas being pushed but loudest at cruising or idle.
Where has all my horsepower gone
Anyone else have this problem ?
Im not popping any codes
Should I get a new TPS ?
This problem came from taking off my TBI which ive done tons of times, modding it and putting it back on.
Old Feb 22, 2009 | 03:17 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
The high pitch noise was my Tbi-manfold gasket "i put a really thin one on it"
That problem solved
Still no power !!!!!!
doing a 180 u turn i can barley get the rear end to slide
Its got fine go under part throttle, feels great unless its smashed
It will down shift and sit at 4 grand not move the tach then shift gears
Anyone help !!!
I would love to make the camaro night at sac raceway but how my car is now, wont be attending unless I can get my power back
Old Feb 22, 2009 | 03:33 PM
heavyduty's Avatar
Car: 1991 Camaro RS
Engine: stock 305
Axle/Gears: 4th gen with 342's
Re: TBI Woes
check your vacum lines running from the tbi to the charcoal canister behind the driverside headlight.
Old Feb 22, 2009 | 04:07 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
did and there good I just checked for leaks so all vacuum leaks are good unless its to small for carb cleaner.
Man this is a PITA
Would a video in car at wot be some help ?
Old Feb 22, 2009 | 06:48 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
SO i took the car out for a few hours, not so much fun. Made some videos and some sound clips only to get pissed at my phone for its crappy sound on my video but good video ? go figure
Now it takes forever to get to 60 and its starting to surge, im guessing fuel pump
Old Feb 23, 2009 | 12:36 PM
89rs454's Avatar
Car: 1989 SS
Re: TBI Woes
Make sure you have your injectors in the right way, there is only one way they will go in and work. I can remember when i had a 305 i had my injectors in wrong and drove it down the road all it did was surge and act like it had no power. By looking at the first pick you posted it looks like the injectors are leaking in the front? Correct me if im wrong.
Old Feb 23, 2009 | 12:54 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
Naw no injector problems, Ive rebuilt a few of these units already, your right about the injectors only going in one way, got that lil slit that that lil circle **** at the bottom fits in, while trying to twist it in so the O ring dont mess up
The POD was rebuilt a while ago, no problems with it.
I took it off for the grind down of the TBI
then put it back on
THats not liquid you see, its a test area on the pod where i was sanding. Wanted to see if it would polish up, maybe allow more air to allow by
By this point im pretty sure its my fuel pump gonna try and get my video and sound clip up.
Old Feb 23, 2009 | 01:02 PM
dctrumpet's Avatar
Re: TBI Woes
Helpful tip when installing TBI injectors:
1. Lube the lower injector o-ring well with a WD40 and place the o-ring in the bottom of the injector pod using a blunt/round object. Make sure it seats well in it's final position.
2. Place the metal washer in it's seat in the top of the pod opening.
3. Lube the upper injector o-ring well with WD40 and seat it on top of metal washer. (note: many people leave out the washer. It is essential to keeping the upper injector o-ring in place and secure).
4. Place injector with injector "tab" lined up with the slot in bottom of pod and gently push the injector in place and watch for the bottom o-ring to make sure it's not being pinched.
5. Firmly, but gently push the injector down and you will hear a nice "pop" and the injector is now installed.
If the injector o-rings (upper and lower) are lubed well then the injector needs NO twisting or excessive force to install.
A nice crisp "snap" or "pop" should be heard. I have installed hundreds. So easy to do once i learned these tricks.
Hope this helps someone.
Sean
Old Feb 23, 2009 | 01:19 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Re: TBI Woes
maybe it's stupid to suggest, but when i retard the timing, i have the exact same symptoms you're describing. Maybe during the course of working with things you accidentally wiggled the distributor a bit and retarded your timing.
Old Feb 23, 2009 | 01:25 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
When my dizzy was 180 backwards I had more power posting video and sound here in a sec had to convert from cell phone format blah!
Old Feb 23, 2009 | 01:38 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
Ok here are some videos, turn your sound down as my phone does crappy sound on the video but good sound on sound record hmmm
http://kizap.com/1.avi.AVI
http://kizap.com/2.avi.AVI
http://kizap.com/3.avi.AVI
http://kizap.com/4.avi.AVI
http://kizap.com/5.avi.AVI
http://kizap.com/6.avi.AVI
http://kizap.com/7.avi.AVI
http://kizap.com/8.avi.AVI
http://kizap.com/9.avi.AVI
http://kizap.com/10.avi.AVI
http://kizap.com/badcar.wma
Old Feb 23, 2009 | 01:54 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
Please note all these videos and the sound clip are at full throttle. and from 30-50ish mph
0-20mph takes about 5-10 seconds to achieve now
Old Feb 25, 2009 | 08:54 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
So I replaced the fuel pump, and to my avail no luck ! Still doing the same thing "insert mega cusswordage here"
Anyways, I think my cat is plugged, or toast or w/e .
I have my wife rev up the car and stick my hand behind the exhaust and really dont feel much, a lil warm.
It surges really bad when i can hear the exhaust it jerks foward when i cant of course its surges back, Think a 10 speed could out run me atm.
Old Apr 19, 2012 | 04:37 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
Woa came across my old post, this ended up being a plugged cat! for anyone looking around!
Old Apr 19, 2012 | 05:38 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: TBI Woes
so it runs great now right????
Old Apr 19, 2012 | 05:58 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
It did for a while, drove it from cali to indiana.
Sitting here over the winter, it's got some bugs, and driving it 100mi daily for work takes it's toll.
She is taking me to Florida here in about a week, so it's like a mad dash to fix anything annoying or issue wise before the haul!
Old Apr 19, 2012 | 07:11 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: TBI Woes
please let us know what you find in the bugs. it is great info for everyone.
Old Apr 20, 2012 | 04:54 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: TBI Woes
First bug ive found is this spring, I cant spin the tires going strait from just stepping on it!! This is not right !!
Gave it a nice tuneup, wires, plugs, cap, oils, fluids, seafoam and it runs a nice smooth idle.
Go for a drive, missing a lot of power or I should say making noise but not going as fast, feels like the motor is tightening up, and it smells of gas.
Gonna replace the injectors with new, and not rebuild them. They look good, but looks can be deceiving.
Will be taking a trip down to Florida here in a week see what else I can find wrong with a 1000+ mile cruise.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
