car stalling when started....
Old Mar 22, 2012 | 08:59 PM
Dougie91's Avatar
Car: 1992 Firebird convertible
Engine: 5.0 tbi
Axle/Gears: stock, slow and steady 2.73's
Once and awhile my car stalls when I start it. Then I start it right back up and its fine. Why is this
Old Apr 4, 2012 | 06:15 PM
hamp1169's Avatar
Re: car stalling when started....
Mine did the same thing 4 a while then I had to put fuel pump on its starts then cut off right? Sometimes right.?
Old Apr 4, 2012 | 07:26 PM
greg9187's Avatar
Mine did the same it was the idle air control
Old Apr 4, 2012 | 08:31 PM
Dougie91's Avatar
Engine: 5.0 tbi
My fuel pump is like 2 years old so it shouldn't be dead already, and im not sure what the idler thing is
Old Apr 4, 2012 | 10:34 PM
tman92's Avatar
Car: 1992 Camaro RS
IAC is an idle air control valve located on passanger side of TBI above the TPS. Also if you used an aftermarket fuel pump from a local parts house it is most likely it was made in China and they are not long lifed pumps. Had to replace two in my truck in a year. Third one is a Delphi from GM and no probs for three years.
Does the car stay at a higher idle for awhile after it is warmed up? If do suspect the IAC.
Check your refrence voltage at both the TPS & IAC at startup.
Old Apr 20, 2012 | 05:41 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
also a sign of a failing ignition control module! Have you fixed your issue ?
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
