1.6 Roller Rockers
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
1.6 Roller Rockers
Okay, I am planning on doing 1.6 roller rockers, but how much of an improvement in power is that really going to have with the stock peanut cam in my LO3? What's the max lift I can run? Am I going to need a chip/tune for this?
Car: 92 camaro rs
Engine: lo3 305 tbi
Axle/Gears: 2.73 , 3.42 soon
Re: 1.6 Roller Rockers
It'll run fine w/o a tune I did mine and underdrives at the same time. It was a good seat in the pants difference real easy to.
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
1.5 1.6
---x---
stock|Y Solve for Y.
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Educate yourself on rocker arm geometry. Just swapping in different ratio rockers may require different length pushrods. While it may be close enough, you may damage the rockers in the long run.
My suggestion: Find another block and start from scratch. Or since you have already got another daily driver, just start with your block. Point being is that I believe in the approach of matching components and tuning once, rather that an add on here, another later. Take your stock block if the rings are OK, and get heads, cam and rockers. Could do it cheap for 500 or so used.
The 1.6's power improvements will be minimal at best with that cam. You should not have to change the tune for it to run ok, but your stock tune will not take advantage of the upgrade unlike a MAF based PCM.
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Running incorect length pushrods will not hurt your rocker arms, it will cause excessive valveguide wear , so you will need to check for it, I do not believe it will be off enough to justify new pushrods, but better to be safe than sorry, checking pushrod length is no more difficult than changing rocker arms.
I do not believe you will see any seat of the pants difference from this, you will gain valve lift but stock heads do not really flow past .400 or so, your only real gains will be from less friction. I do still say it is a good mod, because it may help the car run better now, and if you ever upgrade any other parts of the motor, especially the cylinder heads, then the mod will pay off later.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I posted the actual lift changes in my "synopsis" post but here you go...again.
Stock L03-L05 camshaft 10088155 179/194 - .350/.384 109 LSA
Stock cam W/1.6 rockers 10088155 182/197 - .373/.410 109 LSA
as far as a difference when I first put on my 1.6's the car just felt better all around. I noticed a better ability to breathe in the upper rpm's. I know with tuning it would be more beneficial. With the 1.6's you don't "have" to have new pushrods. I know many people who have swapped to them with no ill effect. I have been running mine for YEARS with no problems.
Car: 83 Z28
Engine: 406
than buying a 25$ set of pushrods, he should buy a new engine block? Did I miss something here.
If others are saying it will give ya some SOP feel, go for it I guess. Hey, at least I did not say stop wasting your time with a 305.
Car: 1990
Axle/Gears: stock
is there a formula for setting pushrod length.
if you go from 1.5 rockers to 1.6 and then you change the cam from stock to a zz4 - how do you get the right length determined in advance?
i have the zz4 cam so its 474/510 already and i got the pushrods with it as well as the springs.
so is there a formula to determine if i have the correct rod length or do i have to hit and miss with it?
dont mean to hijack the thread but it appears the answer fits into the original problem.
thanks
thanks
Here is a good tool that I use to determine the changes in rocker ratio, also IIRC duration changes by two or three points up when ratio changes. So if the ZZ4 cam is 208/221 @.50 474/510 then it should change to 210/224 @.50 506/544. I hope this helps.
http://www.thedirtforum.com/rockercalc.htm
Car: 83 Z28
Engine: 406
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Probably the biggest potential problem is the pushrods interfering with the pushrod slot/hole in the head since the 1.6's move them closer to the valve to increase the ratio.
I would say that the 1.6's wont give you much gain for the money spent, but if they are good rockers such as comp cam magnums, they wont flex as much as the cheesy stock stamped ones do, which helps transfer more lift to the valve.
Youd be better off spending the money on an LT1 cam and tuning equipment. For almost the same money you will get more power than the 1.6's can give by themselves.
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
i also remember reading that the stock stamped POS rockers can have ratios of 1.39 up to 1.52 due to tolerances.. i guess you'd also pick up some smoothness and prolly also power here.
i'd be very interested as to how the stock pushrods (holes) fit with rockers like the comp cam magnums.
Car: 1990
Axle/Gears: stock
i called a number of shops but they all want to see you a full set instead of just 8.
I plan on using the ZZ4 cam in my the near future but I'll be using 1.6's on the intake and 1.52's on the exhaust. that should put my exhaust at about a .517 lift.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Just FYI to all, if any of your combo's exceed .480" lift you will want to have the valve guides cut and the pressed in studs removed in favor of screw in units. An LT1 cam with 1.6 rockers is pushing it on stock heads.
Luckily for me ZZ4 heads already have 'em,lol.
Car: 1990
Axle/Gears: stock
pm and let me know whey you do and i will go in with you on a set of rockers because you have to buy a full set and you will only need half of them - for the intake, same as what im doing, provided we are looking at the same rockers.
Actually I already have them. I've got everything I need to do this but I've just been to busy with work and school to put everything in, lol
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Hey Shifty. Will a lt1 cam be a worth while swap on a stock lo3? I have to start some place. Found a used cam for $25. anything else needed to swap the cam? What do you recommend? If I spend much more on the car, this year my wife is sure to kill me, but I'm tired of the "slowmaro". Anyone have any power numbers on just the cam swap?
Car: '90 RS
Engine: 377 LSX
However, there are additional costs with the biggest being chip tuning. You will need to invest at least $200 to $300 for the equipment to tune and hours of your own time to learn how to do it.
Other than tuning, parts and gaskets are cheap.
Timing chain - $50 to $100
Timing Chain gasket - $15
Intake gaskets - $20 to $30
Valve Springs - $60 to $100
Tool rental (if you don't have a valve spring compressor or balancer puller/installer)
I must emphasize that tuning is a 100% must. If you cannot devote the energy to tune a cam I suggest sticking to the basics mods such as full exhaust (which should be done before any cam swap anyways) and suspension upgrades.
Car: 89 RS
Is it worth it, yes. It is a good cam upgrade over stock because the cam is cheap, and using the stock rocker arm ratio will allow you to get away with the stock heads.
info, but rob just recommended springs. huh. Well if I do had to spend all that cash to swap it, then ill have to just let the cam sit for a while. I am on my way now to buy the cam.
I was going to tell you exactly what shifty did but he beat me to it, lol any time you dig into a project there are hidden costs involved. I know this all to well. What looks like an easy cheap job can turn crazy and expense quick if you haven't done it before. Even more things you're going to have to buy that weren't listed is new oil, a filter and a new jug of anti freeze.
I did some searching and compiled a true parts list of everything you're gonna need so you can make a "check off list" so to speak.
These are autozone prices. all gaskets are felpro.
Cloyes single roller timing set $25.99
intake gaskets $23.99
Timing cover gasket $9.99
Valve cover gaskets (if needed) $20.99
Manley 22410-16 Springs $79.95 Summit Racing
Manley 23652-16 retainers $62.95 Summit Racing
AC delco PF1218 oil Filter $4.00 walmart
Oil of your choice but I prefer Mobil 1 10w30 syn $26.85 a gallon walmart
The tuning stuff is tottaly up to you in which direction you want to go. It can be cheap or you can get the best stuff you can buy. I got the EBL Flash, ZT-2 WB O2 sensor ( complete kit) and a laptop. That stuff alone cost me almost $1000. Maybe others can tell you what's cheaper.
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Was this what you were talking about robert:
http://www.zeitronix.com/Products/zt2/zt2.htm
If so, do you tune with it then install a standard O2 sensor when you're done?
Also, for those of you who are reading this thread and have been looking, heres a serial to USB adapter:
http://www.newegg.com/Product/Produc...82E16812339013
Car: 89 RS
Well thanks a lot for your help guys. Really helped put it all into perspective.
Rob your the man. Thanks for the price list.
So total cost is around $275 without tuning. I read this mod is good for 25-45hp. I thought that the 25 would be with no tuning.
I dont want to spend the money to burn my own chips, but I know where to get a chip burned for $150, so I wanted to do that. I was wanting to do as much as I could with no tuning, since I cant just buy it all at once.
So heres the next couple questions then. Where do I get the stuff to burn my own chips, that way I can ponder it. Also do I have to have a certain type of lap top? We have a lap top, but its just your standard everyday lap top.
Next question. Is it a must to tune? 25hp is fine for right now. Thats $11 per hp ( with everything else on the price list) with the 25ph gain. Guess I should also add, that at some point I am going to add an open element filter. Does that change anything?
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Pardon me real quick, just a quick question, why was aaron92maro(creator of thread), or w/e his name is, banned? He seemed like a real friendly guy.
Car: 2003 F-150
Transmission: 4R70W
I'm a member on 5GO and hes on there now and hes already had one brush with the mods over there.
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
hahahah, lol, wow, I searched all his posts and found the one about the 305 HO or something, LOL hilarious.
Car: 2003 F-150
Transmission: 4R70W
Car: '90 RS
Engine: 377 LSX
Yes it is. Others will dissagree but I suspect it is because they never really drove a cam'd LO3 on the stock tune. If they did, they must have more patience than me. I have driven two. Both drove like garbage. My first LT1 cam swap was 5 years ago and when I was done the car was slower, ate gas, idled poorly, and all around driveability was terrbile. A little tuning goes a long way. stay away from off the shelf chips promising to dial in your tune on the first try from info you supply in an email. Any cam swap in an L03, even with a $20 LT1 cam, must be treated the same way.
Car: 1990
Axle/Gears: stock
i was reading on this last night and with a roller can already in a roller cam swap was pretty simple and you can keep and use your old roller lifters.
so if you go from stock to a zz4 cam there should not be any problem.
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
i thought you only needed those mods if you changed from a flat tappit to a hydraulic roller cam. doesn't a 92 already have a hydraulic roller cam and hence all of those mods? or do i have it backwards, or ami just plain wrong?
I'm pretty sure the L03 comes with a hydralic roller cam, that's why the LT1 cam can swap in without changing lifters/pushrods (i think), it may not be best for performance but it'll still work.
Car: 1990
Axle/Gears: stock
but all of the info about timing chains, etc would not apply to a hydaulic to hydraulic roller cam - or would it?
i have too many miles on my hyrdaulic rollers so im getting new ones too, but the chain and everything else is good and tight.
Car: '90 RS
Engine: 377 LSX
Your 92 does indeed have a hydraulic roller set-up, however you needs those parts to support the new specs of the cam. The timing chain needs to be replaced because they stretch over time. You need new intake gaskets because those are not reusable, you will see when you take them out. The valve springs are needed to support the specs on the new cam. The stock ones are tailored for the stock cam. You need to buy springs that support the LT1 cam specs.
Car: 1990
Axle/Gears: stock
so shifty the new chain is simply because of wear not because they are going from a flat tap to a roller. that makes a lot of sense. already know about cant use gaskets stuff but wanted to make sure i was not missing something about needing other things or i misjudged what kind of cam or rollers i had.
you appear to have a good grasp on the topic, so do you suggest getting new rollers or using the same ones - and can you get them rebuilt.
Car: '90 RS
Engine: 377 LSX
Car: 89 RS
well im going to use new lifters that came with the cam and the zz4 springs too.
Car: '90 RS
Engine: 377 LSX
You are going to want a new one. You are going to stress the worn stock one more with your new combo and it is cheap insurance. You will have the top end of the motor all torn apart, the $100 is worth it to have a new chain that is stronger, and more precise.
KO1
16
Oct 15, 2015 05:00 PM
