89 TBI Problem
Old Mar 16, 2009 | 08:14 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
89 TBI Problem
So i'm going on the highway a couple days ago and around 70mph i start to get this "giving out" feeling from my engine, it feels like its not getting the proper amount of fuel kind of sound it gives me and feeling, because its like a heaving action from my car giving a frontal jerk in a way. This has been happening a couple days and i just swapped the distributor coil to see if that would be the problem but its not. I'm curious if anyone could help me with this asap?
Old Mar 16, 2009 | 08:39 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: 89 TBI Problem
Sounds like a transmission problem.. What's the fluid like? Burnt? Low?
Old Mar 16, 2009 | 08:51 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 89 TBI Problem
Really the transmission fluid could be doing that? Well my father did replace the gears in the rear of the transmission for the speedo to work.. I don't know if that affected so much of the fluid. I'll have to double check about that.. Is there anything else it might be?
Old Mar 17, 2009 | 05:44 AM
Kevman's Avatar
Engine: 2004 LQ4
Re: 89 TBI Problem
Usually burnt fluid means your tranny is toast.. We've got a work truck that around 80km/h it jumps and kicks around like it's trying to find the 4th gear.. maybe thats all it is?
Old Mar 17, 2009 | 05:55 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 89 TBI Problem
I'll check the fluid, but its only at about 70, after my father worked on the tranny just for the speedo gears in the rear. Thats when it started to do that, a couple days later... but i'll check fluid
Old Mar 17, 2009 | 07:14 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 89 TBI Problem
I went to warm my car up this morning let it sit for 5 minutes then checked the fluid. It was like cherry red and bubbling, but i didn't have anything to my convience so i drove to school then checked it, this is like 25 minutes later. It was just natural and see through but dark, not clumping or like burnt. I don't think its the oil... :[ Anything else it might seem like?
Old Mar 17, 2009 | 08:09 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 89 TBI Problem
Acts like it's starving for fuel? Possible deteriorating distributor ignition module. Will behave okay at some lower speeds until the module becomes saturated with heat. Module will eventually fail. This is one possible idea..
Old Mar 17, 2009 | 09:26 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 89 TBI Problem
Yeah i already replaced it and swapped, that wasn't it. It just felt like it, because i had my idle die on my once because one injector wasn't on at the time so thats what im relating too. But i just wish this was easier.. lol :\
Old Mar 17, 2009 | 10:14 AM
Wadebryant's Avatar
Re: 89 TBI Problem
What coil did you replace? The external coil or the ignition module inside the distributor housing, under the cap?
Old Mar 17, 2009 | 08:22 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 89 TBI Problem
Oh i replaced the external one. Not the one under the cap...
Old Mar 17, 2009 | 09:05 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: 89 TBI Problem
Ignition control module is under the dizzy. If this goes out at all, your SOL and your car wont start.
Do you have full performance or does it feel like its missing a ton of power?
Old Mar 17, 2009 | 09:28 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 89 TBI Problem
Feels I still have full performance
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
