SES light when on expressway (110 km)
Old Apr 8, 2009 | 03:23 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, my car has been good for well over 800 KM. I only had a few loose bolts to tighten up, and the rear end dope was low, but anyway.. The first time my SES light came on was today. It's a 52*F day, and I was cruisin down to buy some Corona, and get some gas. I hit the expressway going 110 KM/H and after about a minute my SES light popped up. Could it be because of my open element air cleaner, and the cold air rushing in?
Old Apr 8, 2009 | 03:27 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: SES light when on expressway (110 km)
EGR valve.....for sure..
Old Apr 8, 2009 | 04:52 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
X2 on EGR.
But to be specific.... EGR solenoid!
The ECM applies power to it, it's supposed to open, letting vac to the actual valve.
ECM has no idea if the valve itself opens or not. It just gets feedback from the switch inside the solenoid that is supposed to close when it gets vac applied to it.
You can quite often take it apart and clean it up. Or replace it for a couple hundred bucks (new).
Don't be tempted to bypass the switch! If you "lie" to the ECM that way, you do all sorts of nasty damage. ECM thinks it's getting fuel from the EGR stream, so it leans out the mixture, and screws with the timing. With no actual EGR stream, you'll go lean, and possibly burn up the engine.
Check for cracked plastic vac lines. Very (!) common fault.
I tend to replace them all with rubber hose.
Old Apr 9, 2009 | 05:48 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
2-3 horsepower, going from a 3" diameter suck hole on the stock to a full open air cleaner? Put the drugs down man.
Now If you advance the timing, new plugs, wires, fuel filter, more open exhaust, and clean out the TBI unit, it wakes the motor up, quite alot, too.
Jeez! and Im the one thaking the drugs?
Old Apr 9, 2009 | 04:05 PM
Kevman's Avatar
Engine: 2004 LQ4
Yup, you sure are.
Old Apr 9, 2009 | 04:09 PM
Engine: L98 494hp
Originally Posted by dr.fiero
X2 on EGR.
I agree...except I didn't think the egr has anything to do with fuel mixture...I don't even have an egr anymore...and no problems....egr = exhaust gas recycler/recululator so it should just be putting dirty air into your motor to 'reburn' so to speak....
Old Apr 9, 2009 | 04:59 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
actually, two things:
1. it's exhaust gas recirculation
2. the "dirty air" (exhaust gas) routed into your intake takes up a specific amount of air, thereby reducing the amount of air that is required to be mixed with fuel and hence reducing fuel consumption. the ecm needs to pull out some fuel for this and add some spark advance to burn the leaner mixture (normal mixture + exhaust gas).
Old Apr 9, 2009 | 05:53 PM
Kevman's Avatar
Engine: 2004 LQ4
I went through my Chiltons manual this morning.. It seems easy enough to get it off the intake so I'm gonna give it a go. I priced out a new one at 149.99, so I'm gonna clean out the old one and see if there's a difference. I'll update tommorow morning.
Old Apr 9, 2009 | 08:14 PM
Kevman's Avatar
Engine: 2004 LQ4
I got bored and did it tonight.. The valve was stuck closed, and I had a broken vacuum line, so I redid most of them.. I also found one on the front drivers side on the Throttle body that was capped off, any ideas on what it could be?
Old Apr 9, 2009 | 08:16 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
https://www.thirdgen.org/forums/faq-...-diagrams.html
Hope that helps.
Old Apr 9, 2009 | 11:09 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Pull up your code in TunerPro some time....
Or I can post it.
It's all there.
Subject has already been cleared up, but....
Old Apr 10, 2009 | 08:56 AM
Kevman's Avatar
Engine: 2004 LQ4
Originally Posted by osirus
For some reason it won't let me open them up...
Old Apr 10, 2009 | 09:01 PM
Kevman's Avatar
Engine: 2004 LQ4
A few vacuum lines crumbled in my fingers so I changed them out.. I used some nice silicone ones we had from our other project car.
I notice a strong hissing noise when I start the car up, I think it's for the thermac, but I can't find out where it's coming from.
Old Apr 10, 2009 | 09:29 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Tbi's are pretty noisy down the throat. Make sure youre not just hearing that. It's fooled me a couple times!
Old Apr 10, 2009 | 11:23 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Yeah, I guess you have to be a member now or something. lame.
Old Apr 12, 2009 | 06:35 AM
Kevman's Avatar
Engine: 2004 LQ4
Seems to run alright now.. Changed the oil.. Royal Purple 5W40..
I also found a problem with my rear brake from the beginning, For some reason the barb on the ebrake pulled out, I didn't even notice until I pulled the ebrake, with the drum off.. Damn thing.. I used a stainless hose clamp, and a washer to fix it..
Old Apr 24, 2009 | 08:27 PM
Kevman's Avatar
Engine: 2004 LQ4
Bump: Light's back on.. I bought a TBI Rebuild kit today, so I'm going to do that and see if the problems return. I think it could be an O2 sensor, but times is hard.. I'm broke.
Old Apr 25, 2009 | 08:20 AM
Icarus 402001's Avatar
Car: 92RS
Did you follow rule # 1 and pull codes?
Old Apr 25, 2009 | 09:01 AM
Kevman's Avatar
Engine: 2004 LQ4
I've had an EFI car for 4 years and could honestly never figure that out.
Old Apr 29, 2009 | 06:06 PM
heavyhalf's Avatar
Car: Truck/Bike
Engine: 5.7LTBI
Transmission: THM400
Axle/Gears: 9.5" 14 bolt
http://sethirdgen.org/dtc.htm
Read that, it's stupidly easy, you really should do it.
383cam
Sep 9, 2015 06:01 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
TBRays98
Sep 6, 2015 05:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
