Please help me with IAC
Old Apr 9, 2009 | 08:37 PM
louiethebats's Avatar
Car: 1991 Chevy Camaro RS
Engine: 305 BORED to 310
Ive been trying to adjust my NEW IAC valve and have had no success in doing it like the book/web link specifies.
It says to adjust idle speed to 450rpm.....this is what is not working.
when i do this then reconnect the IAC and attempt to start the car it wont start...just turns.
i am running a small cam-comp cams 08-500-8 cam.
could i be off on something??
the reason why i even started trying to adjust IAC is because after running on street at wide open throttle and coming to a stop, motor will idle around 500 and move up and down until it goes up to 1000. kind of feels like it
wants to die during that time.
thanks in advance guys.
Old Apr 10, 2009 | 01:46 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Re: Please help me with IAC
The ECM needs tuning, bad. That's the problem, not the IAC. While that is a small cam, it's still much bigger than the stock cam. Put a timing light on it and try advancing the timing a little, that may band-aid the situation, but you need to read the stickies about tuning asap.
Old Apr 10, 2009 | 09:13 AM
well i have tried that too. i had to advance the timming almost to 20 degrees. it did not run good at first when i had it a 6. i kind of just played with it unitl i found a spot that worked best for me. anything else that you could think of? thanks for your reply.
Old Apr 10, 2009 | 11:10 AM
Ronny's Avatar
You need to get a tune. either DIY or try tbichips.com
Old Apr 10, 2009 | 05:58 PM
i have read the one about tuning with o2 sensor. is that the one that you are talking about? if not could you tell me which one i need to read.
Old Apr 11, 2009 | 03:06 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
This if you whant to keep your slow limited ECM.
https://www.thirdgen.org/forums/tbi/...free-tune.html
Or better and easyer if you upgrade your ECM to a EBL flash.
http://dynamicefi.com/
https://www.thirdgen.org/forums/diy-...uning-ebl.html
And there are plenty other treads.
Old Apr 11, 2009 | 07:00 PM
ok. it makes sense that i would need to up the ecm i thought that because it was a small cam i would not have to get the ecm messed with. if i would have known this before i would have invested into gears,trans and heads. not that i wont now but, i would have had more fun with those mods instead of a cam. thanks for your replies guys. if anyone out there has installed a cam and did not have to up the ecm please let me know what you did.
Old Apr 13, 2009 | 09:52 AM
Ronny's Avatar
First thing is to secure a laptop. Download winALDL or TunerproRT. Buy or build a ALDL cable. Read stickies on DIY-prom regarding datalogging. Then datalog. You will be using your current NB02 sensor to provide feedbak to your ECM. That will give you BLM data. BLM data will tell you what fuel cells need to be addressed. That will get you started. Other areas to be addressed are AE aka pumpshot PE aka WOT.
Old Apr 13, 2009 | 04:37 PM
thanks for the advice im probably going to use pcmforless to customize my first chip then i will go from there and start datalogging to fine tune it along with more mods. that sounds good right??
Old Apr 13, 2009 | 05:03 PM
Ronny's Avatar
You wont like the answer from many of us. DIY tuners are just that. We do it ourself and make it the best it can be based on our level of competence. Mail order tunes are "ballpark" tunes and those tunes are not optimal. Sometimes they just suck. Sometimes you can get lucky. Even with emailing datalogs back and forth it just does not work as well as you would like. I cant imagine enduring that level of frustration. Check out TBI sticky "come in for free tune". good reading.
Old Apr 14, 2009 | 06:30 AM
thomas1976's Avatar
Car: 91 Trans am
I really suggest to get an EBL flash in first place for someone that is going to continnue upgrading and modding the engine.
If you get an ALDL cable and everithing you need to tune the chips, the EBL isent much more expensive. Thaking into accout the time spent in tuning the EBL is a must.
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
