Cam question
Old Jul 5, 2009 | 08:13 PM
vt89rs's Avatar
Car: 89 Camaro RS, 79 Camaro z28
Engine: 385 stroker
Axle/Gears: 3.23 posi borg warner
Cam question
i was reading in the closed thread, NEW to TBI that you need to use a roller cam shaft in 88 and newer TBI. why is that? edelbrock makes a cam shaft and solid lifter package for this engine, is it junk? i was thinking about upgradeing to it. should i go with something else?
Old Jul 5, 2009 | 09:07 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: Cam question
your 89 has a hydrualic roller cam from the factory, crane used to make a solid roller designed to be used in our engines, but crane went away so I don't know where you'd get them, but the were expensive.
why a solid flat? do you plan to keep it fuel injected? if you do, ditch the solid flat it'll set off your knock sensors all day(a solid roller prob would too).
what do you want out of the car? how much do you plan to spend?
Eric.
Old Jul 6, 2009 | 07:22 PM
vt89rs's Avatar
Engine: 385 stroker
Re: Cam question
Well actually I have this cam in my car, also have the edelbrock tbi intake, Shorty headers to 2 1/2 flow master exhaust with cat delete. Underdrive aluminum pulleys, 160' stat with a hypertech chip, tbi spacer, and a 12" open air filter. It seems to run good with no codes or anything. I would like to get a little more out of it. I have a pair of vortec heads from a 305 and a vortec carb intake I want to put on. I was just gonna make a plate to put my tbi on. I was thinking about carb but don't know what it takes to convert it. Any help/ideas/thoughts would be much appreciated. Thanks
Old Jul 7, 2009 | 08:49 AM
ericjon262's Avatar
Re: not a Cam question
well if your motor still has swirl ports, the vortecs would make a good bit of difference, but they may need to be clearenced for the lift of your cam.if you want to switch to carb, check the carb board, all the info yoou need is over there.
Old Jul 7, 2009 | 05:28 PM
vt89rs's Avatar
Engine: 385 stroker
ok thanks, Am i going to have to get a new chip or reprogram the stock one? which i have no clue on how to even start.
Old Jul 7, 2009 | 10:23 PM
ericjon262's Avatar
I would re tune it, the more efficient heads will allow more air in, and lean out you exsisting tune.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
