305 Valve springs
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
305 Valve springs
do these L03 come stock with springs with dampeners in them?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 305 Valve springs
no , not meant for real performance . lo3's are meant to last at long time (they do) . its a common up-grade if you get in-to the head . good luck .
reason why i asked is i just cracked mine open today and found em in there, the block was replaced at one time, im assuming the dealer put the upgraded springs in at that time, i was going to put the LT-1 cam in, should i even bother replacing the springs since the upgraded springs are already in?
ambainb
Apr 25, 2016 09:21 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
