Engine idles funny, rough then sooth almost miss
Car: 91 Rs Camaro
Engine: 305 tbi
Transmission: 700 r4
This has been happening for a while. Im not sure if it needs to be cleaned or the cable needs to be lubed or what. Not even sure if it is my throttle body
Re: Engine idles funny, rough then sooth almost miss
Maybe it's something simple. Check vacuum hoses for leaks, and retorque intake manifold bolts and tbi bolts to proper specs (I don't have them).
If that doesn't fix it, you might consider a tuneup (plugs, wires, cap, rotor), or it could be a sensor problem, etc.
