I got some vortecs, now I have ?'s
Old Aug 20, 2009 | 07:48 AM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
Axle/Gears: 2.73 , 3.42 soon
I just got a pair of 062 vortec heads they will be milled to 58cc because I'm going to put them on my 305. My question is should I port and polish these or leave them alone get a valve job, valve spring kit, mill them and bolt them up. I've been reading alot most studies are done on 350's but they don't gain hardly any from porting. So I was just wondering. The plan is to get the vortec cyclone manifold idle-5500, and the 08-302-8 210/220 tbi cam from comp cams 1200-5200. I already have every bolt on and the 305 was rebuilt 4 years ago and runs perfect. I'm going to get ebl and dial in what I have already and then do the modding , but I just wanted to know what others have done and if it was worth it or not. Thanks for your help. I forgot I can get a zz4 cam for free but theirs not many ppl running them in 305s so not sure about that just throwing that in there.?
Old Aug 20, 2009 | 10:43 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: I got some vortecs, now I have ?'s
I was wondering the same thing. but along with you i'm curious on what should i look towards for vortec heads for my L03 305? Its an 89 tbi, so i'm wondering on intake manifold and what type of vortec heads, and i was planning on getting new springs and arms , and seats,too just to freshen them up.
Old Aug 20, 2009 | 12:23 PM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
vortec heads ending numbers 059, 062,or 906,intake any vortec compatible will work carb ones will need tbi adaptor, sdpc spring kit.
Old Aug 20, 2009 | 12:58 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
whats the difference from all those vortec numbers? and is there a way to understand heads a bit more, with about cc and other mathmatics to know what would be best for me? also knowing about lift, etc...
Old Aug 20, 2009 | 12:59 PM
MaDeNMiAMi305's Avatar
Car: 92 CaMaRo RS
Engine: CARBED 350 5.7
i guess i have alot more research to do.. i was gonna slap a set on my 350. why wouldnt they benefit as much from porting work?
Old Aug 20, 2009 | 01:28 PM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
They do some just not as much as others because their a really good casting.
Old Aug 21, 2009 | 02:40 PM
killa66cam's Avatar
For Timinsk - check out this stuff:
http://www.goingfaster.com/spo/325_h...chevrolet.html
http://www.hioutput.com/tech/343hp/343hp.html
http://www.popularhotrodding.com/eng...cks/index.html
Start there. If you want more, search for 305 build on yahoo or google.
Cam
Old Aug 21, 2009 | 04:43 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
May add this on top of your list.
https://www.thirdgen.org/forums/tbi/...-bolt-l03.html
https://www.thirdgen.org/forums/tpi/...tpi-310-a.html
https://www.thirdgen.org/forums/tbi/...ack-times.html
https://www.thirdgen.org/forums/tbi/...stock-tbi.html
https://www.thirdgen.org/forums/tbi/...head-swap.html
Old Aug 22, 2009 | 09:15 AM
killa66cam's Avatar
I like it. I had not looked in the tech section yet...but am doing so currently. Thanks.
Cam
Old Aug 24, 2009 | 10:43 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
i read most of it, and why does it not explain about having my computer re-programmed? also anything to explain to me about cam lift, cc, etc? so i have a better understanding what i'm purchasing and looking for? so to say more performance for about the same mileage i get currently.
I'd just like to understand more before doing anything thats why...
Old Aug 24, 2009 | 11:11 AM
thomas1976's Avatar
Car: 91 Trans am
Get EBL and tune your courrent set up, you will gain power, better fuel economy and answer your question.
Old Aug 24, 2009 | 11:25 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
sorry but what do you mean it'll answer my question??... will there be a guide or something to teach me so i could understand what i'm doing too?
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
