THROTTLE BODY PROBLEM!! ANY ADVICE??
Old Sep 26, 2009 | 09:53 PM
thirdgennewie's Avatar
I Just purchased a 91 camaro rs 305 and when I start the car it runs for a good 3 seconds and then throttle body starts spitting fuel and the car shuts off , it also makes a funney noise if you could help thankyou i need to get back on the road.
Old Sep 29, 2009 | 09:38 AM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
Re: THROTTLE BODY PROBLEM!! ANY ADVICE??
check your fuel line pressure and possibly change the fuel pump
Old Sep 29, 2009 | 07:46 PM
Waymores's Avatar
Car: 89 Camaro
Engine: 350 TBI
Try changing the coil. And making sure its timed. Do everything you can before you change the pump.. its a pain in the butt
Old Sep 30, 2009 | 10:09 AM
yea i changed the injectors, and a control valve that craked open and was leaking antifreeze everywhere, and u said to try changing a coil where is that ? is their anything else?
Old Oct 20, 2009 | 06:57 PM
ok ive changed the injectors, fuel filter ,I also tested the fuel pressure an got 8pci's.....? and discovered some vacum leaks but the car is still doing the same thing it will run for about an hour an start to shut off while driving or stopped
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
mdtoren
Aug 16, 2015 05:45 PM
