tbi car with hood bump for outside air?
Car: 1991 Trans Am vert
Engine: tpi
ok my car is a 91 firebird base but it has the 'bump hood' and all it does is let some heat out of the bay, im pretty sure the car the hood came on would have had an air cleaner that went up to the vent with a vaccuum powered flap so my question is if im correct and the right aircleaner for this hood works on my setup id be an easy cold air intake but i cant seem to find one anywhere at all iv tried hawks ebay yearone ect please help!
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: tbi car with hood bump for outside air?
That woulsd be the KITT style hood IIRC also called the power buldge? Anyway yes there is a vacuum activated flapper that is hooked to the hood, opening @ WOT for cold air. If no one gets a pic up i can. I'll see what i can do.
Engine: tpi
ok so i am correct tho that this is that hood, iv see pics of them i just cant find one for sale and i would rather not throw 500 bucks at it ya know?
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Mine is open.. I did away with that plastic piece, and put in some diamond shaped expanded steel. You can really hear that TBI sucking air.. Sounds like a blower..
Engine: tpi
i removed my insert as well but all it is doing is venting the engine bay on mine
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 11, 2015 10:11 PM
