mayjor issues anyone help
Old Oct 4, 2009 | 09:51 PM
glhsdrew's Avatar
I am having mayjor troubles diagnosing a problem with a truck I just bought when I got the truck it wasnt running at all, I went over everything one bit at a time hade trooubles getting it started with all the basics covered I have finaly got it running and had it running for a bit. the thing I cant figure out is that when you crank the throttle at abnout 1500-2000 rpm it just starts bogging, the more throtle I add the more it bogs tps and map are both good the fuel system checks good as far as I can tell, injectors regulater ect. timing is good checked repededly even checked valve timing pump as plenty of pressure, any susgetions somthing Im missing, Ists an 88 4.3 sanoma
Old Oct 5, 2009 | 09:56 AM
glhsdrew's Avatar
Re: mayjor issues anyone help
dont mind the typos I was a little rushed ......sorry
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
