fuel pressure regulator?
Old Oct 26, 2009 | 09:07 PM
555's Avatar
555
Car: 90 Z28, 74 Scout II
Engine: healthy 355
Transmission: t-5
Axle/Gears: 4th gen 10 bolt 3.23
Ok.... finally got my tbi fitting for my fuel pressure gauge. I'm reading around 11-12. I was told this was normal. However when I pinch off my return line it jumps up to around 18 and runs great. The problems I've been having is my car dies after it warms up and when I push the clutch in unless I feather the gas. This is all recent due to my 305 to 350 conversion.... Sound like a pressure regulator?
Old Oct 26, 2009 | 09:34 PM
Damon's Avatar
Re: fuel pressure regulator?
Nope, your fuel pressure it totally normal. 10-12 running and 18 when dead-headed is exactly what you should expect from a stock TBI setup. Sounds like a tuning issue or a vacuum leak.
Old Oct 26, 2009 | 09:40 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
+1 on the tuning. my car did the same thing after my 305 to 350 swap. get a chip. i recommend www.tbichips.com
Old Oct 26, 2009 | 09:59 PM
555's Avatar
555
Engine: healthy 355
Transmission: t-5
I got a "tbichip"......... any reason it runs great after its deadheaded?........
Old Oct 27, 2009 | 10:11 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
maybe idle speed is set too low? or as stated above a vacuum leak. Doesnt really sound like a fueling problem if the car runs fine when you put your foot into it. If it was a fueling issue, the car would be running lean in the upper RPM range, not down low.
Old Oct 27, 2009 | 05:10 PM
555's Avatar
555
Engine: healthy 355
Transmission: t-5
upped my idle... now it stays running, just surges a little. If I disconnect my map sensor it seems to idle better.....?
Old Oct 27, 2009 | 05:24 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
surging usually has to do with the tune, hopefully someone else can chime in on this?
Old Nov 5, 2009 | 08:19 AM
morepowerjoe's Avatar
Car: 86 Camaro
I had the same problem for a while. Come to find out I was never getting the engine temp high enough to go in to closed loop before I was tuning everything. So when it went into closed loop it just got worse. I still have a little of the same issue with a slight surge, but it's because I still have a stock chip with 10.1 and a aftermarket cam.
Old Nov 9, 2009 | 01:34 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
I would next recommend a boost in fuel pressure to 15psi, most run better that way, and that will allow you to lower the idle adjustment back down where it belongs. When you unplug the MAP sensor and it runs better I would replace the MAP. Your conversion will need some work getting the right tune in the ECM, time to start a little monitoring & logging.
Old Nov 14, 2009 | 08:29 PM
555's Avatar
555
Engine: healthy 355
Transmission: t-5
I found some "JET" adjustable regulators @ Jegs... any good or bad reviews, thats about all I could think of to boost my pressure, right? I'm hoping it helps with my high rpms, it almost acts like it governs at 4500-5000 rpms running lean as hell.
Old Nov 16, 2009 | 04:48 PM
Ronny's Avatar
Unlikely a "stock" fuel pump can sustain, under load, much more than 12 lbs FP. As they age they become less efficient. If you update to a GM TPI or aftermarket large increases in FP can be sustained under load. I believe Jet offers a good product for reg. Is Jet a stock replacement? Turbo City also offers same. Aeromotive is the best you can buy but not a stock replacement. Aeromotive requires plumbing and capping the stock location.
Old Nov 16, 2009 | 08:37 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Jet is a direct stock replacement of the FPR. It is fully adjustable, but then again so is the stock one with little modification.
Old Jan 2, 2010 | 03:26 PM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
If it's running better with the map disconnected, make sure the map sensor is hooked up to manifold vacuum, not ported vacuum, check your under hood vacuum line routing sticker.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
