Guestimate my HP
Old Oct 31, 2009 | 10:21 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Guestimate my HP
I ditched the 200K + LO3 several months ago in favor of a low mileage 355 that I got from one of my local club members. I drove the car about 200 miles before I started stripping it down for paint. I just started driving the car again about a week or so ago when I finished making it shiny.
I have no idea what kind HP/TQ #'s I'm putting down with this combo and who knows when I'll get a chance to get it on a dyno. All I know is my car is WAY quicker now than it was with the 305.
Here's what I have in it now:
350 block from '96 Chevy truck
Bored .030 over
9.8:1 compression.
Hypereutectic pistons.
HD rods.
LO3 heads ported and polished, 3 angle valve job, machined surface, cut pockets.
Competition Cam, 211/221 @ .050 with .442/.465 lift 110 LSA.
Port and gasket matched intake/heads
Stock TBI with 350 injectors.
180* stat.
Accel coil.
Accel plugs
8mm Accel wires
Edelbrock shorties with custom Y-pipe
Mail order chip
I've done all of the Ultimate TBI mods and run an open element.
I swapped in a T-5 and my ratios are:
Ratio........1st.............2nd.........3rd.........4th............Rev.......5th
T5U..........2.95...........1.94.......1.34........1.1............2.76........63
I have a 3.27 9 bolt from an 89 GTA.
The car pulls extremely hard up to 5K RPM...I don't really push it much past that driving around.
Does anybody know what this combo should realistically put down?
For the record, after swapping this in I have killed two different 4th gen LS1 cars from stoplights up to 100 MPH. (Not in the city...we have a stoplight out in the middle of a 4 lane highway for some strange reason.)
Old Oct 31, 2009 | 10:47 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: Guestimate my HP
I would say it is not possible to give a reasonable hp estimate without knowing flow date for the heads. However, with the cam you are running it would take a heck of a port job on LO3 heads with stock valve size to get into stock LS1 territory.
Old Oct 31, 2009 | 11:59 PM
Jeffs82TA's Avatar
210-215hp
Old Nov 1, 2009 | 12:13 AM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Originally Posted by Jeffs82TA
210-215hp
Ouch!!! I think he'd do a little better than that even without porting the heads.
Old Nov 1, 2009 | 12:23 AM
Jeffs82TA's Avatar
nah ... he doesn't mention TBI mods or different intake manifold and the heads in themselves even ported are boat anchors. The headers help I suppose but I will give the benefit of the doubt
216hp
Old Nov 1, 2009 | 12:38 AM
FYRCHKN's Avatar
Engine: LT-1
216hp
Ha, Ha!!!!
It's a 350 now, not a 305.
I was wondering when I would get the "LO3 heads are boat anchors" .
As I mentioned in my first post I have done all of the Ultimate TBI mods in the sticky. (grinding down the TB, bumping FP, injector spacer, etc....)
I have an LO5 intake.
Old Nov 1, 2009 | 12:44 AM
Stephen's Avatar
Car: 87 GTA
Let's hit the dyno & find out!
Old Nov 1, 2009 | 01:17 AM
Jeffs82TA's Avatar
Originally Posted by FYRCHKN
Ha, Ha!!!!
220hp
Old Nov 1, 2009 | 03:36 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I think this could be close.
https://www.thirdgen.org/forums/post...84-post22.html
Old Nov 1, 2009 | 06:00 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
215 RWHP sounds about right
Old Nov 1, 2009 | 06:25 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i'll recon 240 at the wheels
Old Nov 2, 2009 | 07:44 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
what kinda h.p you putin down alvanwie?
Old Nov 2, 2009 | 08:11 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Reply to "obeymybird":
Never been on a dyno or the track, but Dyno2003 says it should be capable of 400 fwhp.
Last edited by alvanwie; Nov 3, 2009 at 01:56 PM. Reason: This was a reply to "obeymybird"s question
Old Nov 3, 2009 | 12:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A stock valved and unported LO3 head will flow around 165cfm which is good for a theoretical power limit just north of 300. Porting will expand that range but I am not sure if you are near 400hp. I would suspect your car could be a lot faster with some DIY chip tuning. That mail order tune is leaving a lot of power. My geuss is that you are making around 300hp with the capability of making near 340 or so with a better tune and possibly larger TBI unit.
Old Nov 3, 2009 | 12:04 PM
Stephen's Avatar
Car: 87 GTA
Why'd you convert your car to Front Wheel Drive? (Fwhp)
Old Nov 4, 2009 | 04:14 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
IMHO in a street race allot of things can happen, around here ls1 cars run and dyno pretty strong.
For horsepower I always go more by trap speeds at the strip than dyno's. They seem to be more even track to track compared to dyno to dyno. You may be surprised how some cars ET pretty strong with supposed small rwhp numbers.
I always gotta know my "numbers" but it sounds strong. A third with some power is a fun car to drive!
Old Dec 14, 2009 | 12:36 PM
1badz71tahoe's Avatar
Fly Wheel Horse Power
Old Dec 14, 2009 | 01:01 PM
Stephen's Avatar
Car: 87 GTA
And if YOU believe Desktop Dyno HP #s, whos the ?
Old Dec 14, 2009 | 01:46 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Its been proven to be within +/- 10hp several times. If you know how to use it.
As for this engine it shows peak (at the flywheel)
tq 422 @ 3500rpm
hp 388 @ 5500rpm
However, the stock tbi injectors, at stock pressure just won't pull those numbers.
My guess 230-240hp 330-360ft-lbs tq
Old Dec 14, 2009 | 05:04 PM
thomas1976's Avatar
Car: 91 Trans am
tq 422 @ 3500rpm
hp 388 @ 5500rpm
Forget tose numbers! even with pefect fueling and tune.
I think you should read the OP's post again, you must have done some confusion.
italiano67
Sep 22, 2015 08:42 AM
3rdGenHitman
Aug 15, 2014 07:20 AM
pgtr
Wheels and Tires
Dec 31, 2013 06:29 AM
NullHead
Jun 11, 2012 06:11 PM
antscrd
Mar 5, 2011 01:45 PM
