crank no start
Old Nov 2, 2009 | 08:21 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
crank no start
thought it was a fuel pump cause it aint kicking on. BUT payin a lil more attention I noticed the only warning lights that are comein on is my infl rest and seat belt lights then when u crank it they stay on and the brake light comes on.
meaning EVERYTHING else stays dead includeing the check engine light.
could it be the computer just died on me? no joke just rolled off the tow truck 10 minutes ago. it my primary ride so any help as fast as possible would be appreciated
Old Nov 2, 2009 | 09:10 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: crank no start
Ok if you aren't hearing the pump I don't think OBD1 would really pick that up. Check your injectors when you're cranking the car to see if they're spraying any fuel.
Old Nov 2, 2009 | 09:26 PM
Car: 91 RS
Engine: 5.0 tbi
Re: crank no start
yeah already did. injectors arent spraying. no fuel. to late to check spark. I dont think the computer if firing up the system. I dont know I dont wanna get a computer cause I am so close to getting the new motor together. if I gotta get a comp it'll be just a big waste for 2-3 monthes
Old Nov 2, 2009 | 10:42 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: crank no start
You can check Ignition module, fuel pump, fp relay. Have you checked for any codes? That could help point you in the right direction.
Old Nov 2, 2009 | 10:45 PM
Car: 91 RS
Engine: 5.0 tbi
Re: crank no start
havnt checked codes yet no
Old Nov 2, 2009 | 10:51 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Re: crank no start
Also you can try starter spray into the tbi while turning it over to rule out if its fuel related or ignition.
Old Nov 2, 2009 | 10:56 PM
Car: 91 RS
Engine: 5.0 tbi
Re: crank no start
well I know I aint getting fuel cause the pump isnt comeing on and neither are half my dash lights
Old Nov 3, 2009 | 08:08 PM
Car: 91 RS
Engine: 5.0 tbi
Re: crank no start
ok. tonight had my buddy who is an L2 ase engine control tech over. with his scanner hooked up says it's a bad ground. BUT! there is an overly excessive vac leak on the pass side side. workin on it tomo sooo I'll let y'all know what comes out
Old Nov 4, 2009 | 10:03 AM
Car: 91 RS
Engine: 5.0 tbi
Re: crank no start
OK!.....got it figured out.
my rad cap was leaking and filled a connector where I had to replace the powerwire to the pcm and for some reason the coolant burned through the wire and connector so the car would crank but not start so the computer was dead. took me and my engine builder to figure it out and it was right infront of our faces. first thing on the car that was simple and easy. go figure
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Tonyy_z
Aug 12, 2015 07:20 AM
