Wynajammer Supercharger Thoughts
Old Nov 7, 2009 | 07:30 PM
jbk88sc's Avatar
Anyone have any thoughts or experience with the 305 TBI Wynajammer Supercharger?
www.TBI-Superchargers.com
Looks like a decent set-up (kit) thats makes some nice power for a stock car. They do recommend a high-flow exhaust.
Thanks in advance for any help,
Jack
Old Nov 7, 2009 | 08:59 PM
duderjay's Avatar
Car: 88 iroc z28
Re: Wynajammer Supercharger Thoughts
I am wondering about that kit myself. I wonder what cam and compression ration on a vortec 350 with that kit
Old Nov 7, 2009 | 10:11 PM
killa66cam's Avatar
There are some guys running them over on fullsizechevy.com. I think they all seem to like them, but you can probably get plenty of information from there.
Cam
Old Nov 10, 2009 | 04:10 PM
ruberbanman126's Avatar
Car: 1992 Camaro RS, 1999 GMC Jimmy
Engine: 305 TBI, 4.2L I6
Transmission: 700R4, 4L60-E
Axle/Gears: 10 Bolt 2.73, 10 Bolt Posi 3.42
Is the system for 100% stock motors, with the exception of the recommended parts?, and how much more power does it make?
Old Nov 10, 2009 | 04:34 PM
Ronny's Avatar
power output dependent upon boost 6psi = 20-25% 8psi= 25%-30% 10psi=35%-40%
per Procharger
Old Nov 10, 2009 | 05:06 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
What do they spec for fuel system changes?
EDIT: Also. just noticed that they're using a toothed belt to driven the centrifugal compressor. That's a no-no, I'd avoid this.
Old Nov 11, 2009 | 09:11 AM
killa66cam's Avatar
I think they are fine for the boost they're running...the kits are usually 5-6 psi. If you start turning up the boost, then you may have to start worrying about the belt.
Cam
Old Nov 11, 2009 | 10:27 AM
Ronny's Avatar
fuel system changes? Give it what it needs. higher FP and higher injector size AND an ECU that handles boost(2 bar MAP >100). And a stronger fuel pump.
Old Nov 12, 2009 | 12:23 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
why is that a no no??
Old Nov 12, 2009 | 07:54 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Belt driven centrifugal compressors work with an extremely high internal overdrive gear because the the compressor has to get up to 100,000 rpms or so to work well. This gear arrangement, is fragile because of this. The stress of the rapid changes on engine speed, (mostly deceleration under hard braking) can break these gears if a toothed belt is used. With a V-belt the supercharger slips a little when these changes get to high and all is well.
This is one of the reasons you typically don't see centrifugal superchargers on cars from the factory.
Bubbajones_ya
Jul 6, 2024 08:32 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
-=Z28=-
Sep 24, 2015 10:21 AM
RedLeader289
Sep 23, 2015 06:50 AM
IROCZ1989
Sep 4, 2015 11:54 AM
