pressure regulator question
Old Nov 9, 2009 | 08:20 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
i was @ the junk yard and i was looking at different tbi units on different cars , like caprice some potiacs, and cadillacs , i noticed a differance in the bore size and obviously the injector size /flow , but my question is , are the pressure regulators all the same ? , same goes for the diaphragm .
Old Nov 10, 2009 | 03:53 PM
Ronny's Avatar
Re: pressure regulator question
I believe they all use GM 12 lbs for fuel pressure so I believe they are all the same. I doubt attachment pattern did not vary. One exception. The marine TBI units(7.4L) I believe have different springs. As does the 1995-1996 7.4L truck engines have different springs.(26-32 lbs).
Old Nov 13, 2009 | 12:26 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
There are dozens of GM reg part #'s, a half dozen are most common. I think the smaller diaphragm remains the same part, the aftermarket uses 1 diaphragm for 98% coverage.
MustangBeater20
Oct 29, 2022 09:20 PM
wayshegoes
Aug 17, 2015 12:00 PM
redmaroz
Aug 16, 2015 11:40 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
