TBI problem
Old Dec 8, 2009 | 01:30 AM
carfreak614's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Open 2.73
TBI problem
Ok, last night when I ran down the street, I started my camaro up and she started fine, nothing out of the ordinary. But when I pulled out of my driveway and started to go down the street, the RPM's were fluctuating. Not by much, only dropping about 500 RPMs and then snapping back in a split second, but it only did it for a minute and then went back to normal. I thought it might have jus been from the cold but then it was doin it again on the way to work today. This time it was a little worse, but then died down after a couple minutes. When I pulled into work I revved it up and it was doin it again. My dad seems to think the fuel filter might need changed or the pump itself might be goin bad, which seems logical enough, but i was wondering if anybody on here has had this problem?
Old Dec 8, 2009 | 10:11 AM
Fionnla's Avatar
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
Re: TBI problem
When I had my engine setup for TBI I had the same problem and it was the IAC. I not sure if that is your problem but I believe there is some threads on this site that explains how to test it. I attached a pic of the engine electronic arrangement for the TBI. Hope it helps.
Old Dec 8, 2009 | 10:26 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: TBI problem
I had the same problem with my IAC module, i would trouble shoot that first before pulling a fuel pump. Fuel filter never hurts for less than $10 though so.
Not to stray from topic, but Fionnla, where did you get that image? I'm looking for one to do a TPI swap on my Trans Am and it would be extremely useful in the map that you have laid out. If you could PM me the details, that would be great. Thanks.
Old Dec 8, 2009 | 01:03 PM
Fionnla's Avatar
Car: 85 Camaro S/C
Re: TBI problem
Hey 84redta: The boy of mine downloaded that off the Internet about 3 yrs ago and I don't remember where. It may have been off of Autozone's web site. I'll check with him to see if he remembers. Later.
Good Luck with your project.
Old Dec 9, 2009 | 01:10 PM
Car: 92 Camaro RS
Engine: 305 TBI
Re: TBI problem
Well its not the fuel filter, so im gonna run a quick diagnostic on it to see if it pulls up any codes, and then from there im gonna start with the IAC and hopefully that fixes it
Old Dec 9, 2009 | 01:32 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: TBI problem
check for vacuum leaks.
Old Dec 12, 2009 | 08:34 PM
Car: 92 Camaro RS
Engine: 305 TBI
Re: TBI problem
Well it turns out it was the IAC. Hasn't done it since I replaced it. Thanks for all the help guys
Old Dec 13, 2009 | 08:04 AM
Fionnla's Avatar
Car: 85 Camaro S/C
Re: TBI problem
That's great Carfreak614. Sometimes the problem is easy and not to expensive to fix. Now go beat up on some Mustang...Haha.
May you have a great Christmas and New Year and lots of goodies
for your ride, "no wat I meen".
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
