What octane do i need
Old Dec 12, 2009 | 10:10 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Hi i have seen in a thread of the octane for the tbi but i have a question my LO3 has 170k do i still need to put 87 or should i put 91 or 89.
Old Dec 12, 2009 | 10:16 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: What octane do i need
the cheap stuff will do fine.
Old Dec 13, 2009 | 12:21 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
So i should just keep on using 87
Old Dec 13, 2009 | 12:26 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
yeah you dont have high compression so just use the cheap stuff
Old Dec 13, 2009 | 01:05 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Ok thanks i have been using 91 since i thought thats what the car needed
Old Dec 13, 2009 | 07:48 AM
Cflick's Avatar
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
That's easy. The LOWEST octane that does NOT knock on your hardest pull, like the freeway ramp.
Old Dec 17, 2009 | 07:38 PM
Thrillo's Avatar
Car: '89 'Bird
Engine: Low Output Three :-/
Axle/Gears: Peg-leg 2.73
As engines age and carbon builds up inside them changing their compression ratio, doesn't their octane requirement go up slightly? I stick 89 octane in my 'bird because of that.
Wouldn't the knock sensor prevent knock from happening in the first place? The car could be running with retarded timing and the driver wouldn't know it. Just like how modern cars which require 91 octane can be run on lower grades without knocking, but with decreased performance and mpg.
Old Dec 18, 2009 | 12:39 PM
Cflick's Avatar
Maybe. It happens, but is not a certainty.
NO !
The knock sensor senses that knocking is ALREADY occuring, and tells the ECM to react to it ASAP to save the engine. The ECM will then try to restore timing to where it should be, see knock again, and again retard timing, so you're running *past* the ragged edge that way, at least some of the time.
Most engines can stand some degree of knock without severe damage, but over the long haul, I'm not sure anyone knows !
Running on the edge of incipient knock will keep the chambers clean, and not do any damage, but is also before the sensor will detect it so is almost impossible to hit. It may also be more advance than produces best performance anyway, depending on chamber design, and a host of other things.
Old Jan 7, 2010 | 08:42 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
also some people have heard that higher octane cleans your motor this is false. just creates more deposits in your engine
Old Jan 9, 2010 | 08:37 AM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
What people think is that higher octane burns better,,,this is absolute BS, the lower the octane the faster it burns.
The only thing with high octane ,,it runs cooler and is easyer on the valves.
87 is the way to go.
Old Jan 10, 2010 | 11:08 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
A higher octane than what your engine needs could actually hurt performance and emissions due to the fuel charge not completely burning during combustion.
Plus it's more expensive.
Old Jan 11, 2010 | 12:01 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
You only need enough octane to keep your motor from pinging. Running higher octane can slow the car down. You motor for sure needs the cheap stuff.
Old Jan 11, 2010 | 08:24 AM
Cflick's Avatar
All of my research suggests that octane, real or "oxegynated" additive, ( pre-burnt alcohol ) changes the chemical decomposition *rate* in the very high temp high pressure end gases *just ahead of* but not *in* the flame front, thereby preventing the spontaneous combustion ( detonation ) of the remaining unburned charge, but has NOTHING to do with burn rate of the normal flame front as it consumes the much lower temp mixture.
If there;s is any definitive information about octane affecting burn *rate* in any way, I'd certainly like a reference ???
Old Jan 15, 2010 | 05:58 PM
ThreeOhFive's Avatar
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
104 OCTANE.
I have used it a lot. When I have money to blow we run the Camaro down to empty and put about 10 gallons of 104 in it and go cruise the strip!!! Lol it's pretty funny. Suprised it hasn't thrown a rod yet.
Old Jan 15, 2010 | 06:03 PM
Engine: M54 DOHC I6
Axle/Gears: Stock
Double post.
1fast91
Sep 8, 2015 01:48 PM
masonta
Sep 1, 2015 06:40 PM
Justin92GTA
Aug 27, 2015 11:16 PM
355tpipickup
Aug 13, 2015 07:35 AM
