rich running lo3 with data logg vid
Car: 1988 Pontiac trans am
i know i posted this in the DIY PROM section , i just didnt know how to move the thread so here i am reposting
can anyone tell me whats making me run rich right from startup
http://www.youtube.com/watch?v=Jy5PMV3IY-Y
Re: rich running lo3 with data logg vid
really ? , nothing ? , im starting to think i have an intake manifold leak "where the manifold meets the heads" would this upset the air/fuel ratio? , when installing the intake manifold , the guy who put it on ,he applied a bit of RVT sealant to hold the gaskets in place . think the RVT could cause an uneven surface thus the leak ?
Car: 1989 Camaro RS
Engine: 305 TBI
I think if the manifold had a leak, you would get lean conditions. Have you checked your timing, any trouble codes?
yeah , i didnt get any codes ,but here my guess @ the manifold leak . if there was a leak , wouldn't it introduce more oxygen into the engine thus throwing off the air fuel ratio. it would probably cause a lean condition , then the computer would add more fuel to try to correct the air fuel ratio?
